Results 1 to 2 of 2
Thread: PCB milling with Lumenlab Micro cnc machine
    May 2012
    South Africa
    Hi
    I'm looking for recommended spindle speeds and feed rates for milling fibreglass copper board pcb's on a Lumenlab Micro cnc machine in my office. Previous attempts to mill pcb's with this machine have resulted in some pretty poor results on very simple designs from EAGLE CAD and my design is significantly more complex than previous attempts. By the manufacturer's specs the machine should be very accurate.
    I'm using a 0.5mm carbide end mill bit but as these don't come cheap, I would like to get it right the first time and not destroy the bit. The spindle is rated from 500-22000rpm
    Any suggestions?
    Nov 2011
    South Africa
    Hi Jamgee
    How thick is the board and are you trying to mill / cut it into a particular shape?
    Cheers
    cadcamcolin
  1. Milling Copper (on a micro scale)
    By ME-Student in forum General Material Machining Solutions
    Last Post: 10-08-2010, 03:45 PM
  2. New cnc lumenlab
    By hagyy38 in forum Want To Buy...Need help!
    Last Post: 03-04-2010, 11:37 PM
  3. Micro Mark mini milling machine
    By simila95 in forum Benchtop Machines
    Last Post: 10-27-2009, 03:58 PM
  4. Need Help to find micro milling service shop
    By looking9 in forum Employment Opportunity
    Last Post: 03-11-2008, 10:30 PM
  5. White Paper: Highspeed milling with micro-tools
    By HighSpeed in forum Product and Manufacturer Announcements
    Last Post: 03-03-2004, 09:29 AM
