Newbi with Chinese 2520t problem - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 37 of 37
Thread: Newbi with Chinese 2520t problem
  1. #21
    Mar 2016
    South Africa
    Default Re: Newbi with Chinese 2520t problem
    Here is the diagram i built my machine from, Ploter CNC / Drukarka - gotowy projekt - REPRAPOWO - Forum Techniczne poświęcone budowie drukarek 3D
    google ardunio uno with shield diagram, that will be plenty for your nema 17 motors,
    the part you will need a power supply, arduino uno, shield board, and Pololu A4988 driver module.
    forum.hobbycomponents.com - View topic - CNC V3.0 Arduino Compatible Shield (HCARDU0086)
    that way all you parts will be locally available, you can set it up and run it a bit harder if need.
  2. #22
    Jul 2016
    Hi
    The voltages is 18volt on the yellow and 38volt on the blue. I tested the just to make sure the they are giving out power so that is good. The red wire facing you gives out power to the controller.. i just cant think now how much, i will go have a look after breakfast. Regarding the testing, this is how they asked me to test for them
    I will ask them for a diagram, thank you
  3. #23
    Jul 2016
    Quote Originally Posted by melvinbruce View Post
    I saw the uno with the shield on Banggood for quite cheep CNC Shield V3 3D Printer Expansion Board+A4988 Driver+ Geekcreit? UNO R3 Sale - Banggood.com
    Thought it will not be enough need something more
  4. #24
    Mar 2016
    South Africa
    Quote Originally Posted by kimb0 View Post
    Yep that is it, those A4988 can put out 2 amps max, you nema motors are 1,5 amps max, just make sure you use the heat sinks on the A4988 and in you configuration h file for the arduino uno board set you limit there.
  5. #25
    Mar 2016
    South Africa
    Look at this video got some good info.
  6. #26
    Jul 2016
    ok coming from the transformer. blue wire 40volt, yellow wire 20volt. Red wire going down to the control board 43.8volt . I get continues on the stepper looking at the video from the left as pin one on the plug on pin 1 and 2 then 3 and 4 the same if the estop is pressed or not
  7. #27
    Mar 2016
    South Africa
    not quite sure what the question here is, but from what i see there you seem to have all the correct voltages, the purpose of a e stop, is to stop the electrical circuit in an emergency,
  8. #28
    Jul 2016
    Not sure why my last post did not go through. I get the same values no matter if the estop is pressed or not. Like the estop is not working
  9. #29
    Mar 2016
    South Africa
    they may have just a signed the estop in there program to pause or stop it should there be a problem during machining.
  10. #30
    Jul 2016
    They send me a new control box, should be here by next week
  11. #31
    Mar 2016
    South Africa
    Did you ask them for the drawing to fault find?
  12. #32
    Jul 2016
    I did ask hey told me they must get at the engineer
  13. #33
    Mar 2016
    South Africa
    Lol, they always need an engineer. Remember when I use to deal with Taiwan for the blow moulded I use to repair, same story. Need a engineer.
  14. #34
    Jul 2016
    Yea and the lady hellping me is really not clued up. Seem like she just say what was told to her
  15. #35
    Jul 2016
    got the new control bx and everything works again
    question: i am trying to clamp some small objects down with double sided tape, but it keeps on coming loose, also hot glue. Is the some kind of trick to this?
  16. #36
    Mar 2016
    South Africa
    the double sided tape must be good quality 3M, then it should work fine, as for the hot glue gun it must cool down completely.
  17. #37
    Jul 2016
    ok thank you
