Hi All! As the title says, how do I get my code to write x and y on every line? Right now if the coordinates are the same it doesn't repeat the number. Is it the GPP or mac file I edit? Thank you!Similar Threads: Okuma post edit or CAM edit? How do you set your X & Y work coordinates?Need Help!- IMG to Coordinates G92 coordinates G31 uses machine coordinates?
Use the "change ()" command. refer your GPP document for the details
View Tag Cloud
Forum Rules
