I apologise if I have posted this in the wrong place, I am new to this forum.
I am running Mach3 on a Chinese CNC3020 machine.
Models are produced in Solid works and programmed in SolidCAM, the post processor I am using is gmill_Tormach_3x_Eval
My problem is that the Z axis will not move down when running a pocketing or HSM program, it operates perfectly when profiling and during manual operation, but just sits at the same level working through the 'X' 'Y' movements when pocketing.
Have I missed a setting somewhere or am I using the wrong post.
Incidentally, I do not get the same problem when posting from ArtCAM,, the machine will cut a 3D relief with no problem.
Any help or suggestions would be greatly appreciated.
Dave
I would not call myself an expert as I do not get lots of time to practice, I am a manufacturing engineer and tend to problem solve rather than full blown production.
To answer your question ....... yes I have run the solid verify simulation and everything ran perfectly, this is why I thought it may be the post i.e. a problem 'after' the simulation, this was also why I loaded it and ran it in Mach3 with confidence, only to discover the 'Z' axis problem.
Just to add some background, I bought the little CNC3020 to get up to speed with the programming, I am not particularly worries about the accuracy of the machine just how it functions, I am also building a larger 4 axis machine from scratch, so this is all good input.
Many thanks for your prompt reply.
