If you don't use a particular font style for engraving. You can use. DPS Schrift Single font it works well in single line engraving
Hi, the model I was working on had already features of engraving (some text written on it in Arial 10 font), but the milling operation I was about to create to use those existing engraved letters on model, was giving me the geometry is invalid error. No matter which letter I choose.
the model was in stp and opened and saved as solidprt.
The letters were consisted of many little chopped up lines, so the procedure for creating a chain was "auto - constant z", so it would automatically select all those tiny lines and I wouldnt have to pick them up manually one by one.
I ended up deleting the milling operation and creating new engraving operation for each word by creating new geometry, adding text, picking start location and angle and thats it.
solidcam 2015
- Problem- Error: "Invalid shoulder base length" in adaptive roughing
- Need A Quote- 6061 T-6 2"x8" 4th axis milling needed. Have model and sample code. 10pcs minimum.
- Need Help!- Cannot "Select Geometry" in V24 (specifically Engrave) - The geometry is points
- Need 16"x16" Wood Milling / Metal Engraving CNC Machine
- Contouring, "invalid casting feuture data"?
Pick "multi chain" and "text" and click on the text itself.
Sent from my Nexus 5 using Tapatalk
will try thx
I have been trying to make a 3D engraving on a curved surface but SolidCAM keeps on making flat engraving toolpath. No matter how I follow the tutorial of Mr. SolidCAM professor in youtube, I can't get a 3D engraving toolpath....What could I be missing???
