4 Axis Mach 3 Postprocessor (free but kinda wip) - Page 3
Page 3 of 6 FirstFirst 123456 LastLast
Results 41 to 60 of 103
Thread: 4 Axis Mach 3 Postprocessor (free but kinda wip)
  1. #41
    Default Re: 4 Axis Mach 3 Postprocessor (free but kinda wip)
    Hello,
    can you give me for working postprocesor inventorCAM? I tried this postprocesor which is solidcam InventorCAM but not found in direktoriyata.Imam need for working postprocesor 3axis inventorCAM and mach3.
  2. #42
    Hello,
    can you give me a working postprocessor for inventorCAM? I tried this postprocesor which is solidcam InventorCAM but not found in the directory .Imam need for working postprocesor 3axis inventorCAM and mach3.
  3. #43
    Dec 2010
    Earth
    Sorry dude, SC only. I think that InventorCAM uses HSMWorks as the engine so look around for a mach3 post for hsm.
  4. #44
    Jan 2014
    Hi, tried the post from Github in Solidcam today. Unable to make a 4 axis tool path. Is there a tutorial or can you share the files you are using?
    So that I can see what type of operation and geometry selections.
    My machine substitutes x axis with the rotational, rotary axis points to Y. Can I change this in the post?
  5. #45
    Jan 2014
    Hi, managed to get it working sort of, Using Sim 5axis milling set to parallel cuts. But the machining is on the inside of the surfaces. Flipping the direction does not fix the problem.
    4 Axis Mach 3 Postprocessor (free but kinda wip)-cam-jpg
  6. #46
    Dec 2010
    Earth
    Hey - was travelling hence the late reply. Re your first question -- sure, do what ever you want with the post. I have the rotary-along-y version on the todo list, but no plans for implementing it so far, so if you do, please send me the post proc so that I can put it on guthub as well.
    Regarding your other issue -- I've had this happen to me as well and so far have no idea why and when it happens like this. My understanding is that this is a SC issue and not a problem with the post... maybe one with the vmid, but I really have no idea.
    P.S. -- PM me an email of yours so that I can send you the files I've used to test.
  7. #47
    Hello,
    I have a problem with this postprocessor. When calculating the G code and load it into mach3 makes two random rounds in .Operation mm. Here are photos from SolidCam and mach3:
    Here is via the drawing:
    Cam faile
    CAD faile
  8. #48
    Hello,
    Can anybody help with this problem?
    With what program I can edit postprocessors? I have installed SOLIDCAM2015. I can not find the program Gpptool!
  9. #49
    Dec 2010
    Earth
    You use notepad to edit the post definitions (.gpp). Or a better text editor (like notepad++), but in the end it's still a text file that needs to be edited. You use gpptool (MachineEditor.exe actually) to edit the machine definition files (.vmid).
    Machine definitions and postproc files are located at C:\Users\Public\Documents\SolidCAM\SolidCAMXXXX\Gp ptool. Gpptool / vmid editor itself is at C:\Program Files\SolidCAMXXXX\Solidcam\MachineIdEditor.exe
    C:\Program Files\SolidCAMXXXX\Documentation will also be interesting for you I think.
  10. #50
    Dec 2010
    Earth
    Also the links to files you've posted have expired and I can't see what's wrong. Please repost or just PM me new links to files.
    Cheers,
    Teo
  11. #51
    Hello
    Thanks for the detailed explanation.
    These are the files:
    Mega File Upload - Tapa Mach3.rar
    * I would be very grateful if you can solve this problem!
  12. #52
    Dec 2010
    Earth
    Dude, not sure how you managed to get the result you've posted above. This is what I get with your files just clicking 'generate g-code' in solidcam....
    Attached Thumbnails Attached Thumbnails 4 Axis Mach 3 Postprocessor (free but kinda wip)-t2-jpg   4 Axis Mach 3 Postprocessor (free but kinda wip)-t1-jpg   4 Axis Mach 3 Postprocessor (free but kinda wip)-t3-jpg
    Attached Files Attached Files
  13. #53
    Dec 2010
    Earth
    Also this is how the gcode you sent me looks like in the backplotter and mach3.
    Attached Thumbnails Attached Thumbnails 4 Axis Mach 3 Postprocessor (free but kinda wip)-t4-jpg   4 Axis Mach 3 Postprocessor (free but kinda wip)-t5-jpg
  14. #54
    Hi
    the problem comes from the fact that MY units are mm. I asked in IJ Mode be abslyute. When in the Inc was prepared as with you. The question is, can I leave it in inches. They will receive various sizes set? Can you fix this problem in the postprocessor?
  15. #55
    Dec 2010
    Earth
  16. #56
    Dec 2010
    Earth
    So, fyi, besri's problem was wrong ij mode in mach, nothing wrong with the post.
  17. #57
    Aug 2005
    Netherland
    Do you guys also have this Postprocessor for SolidCam 2013 were the .PRP file is needed.
    Many thanks,
  18. #58
    Dec 2010
    Earth
    If I have the time over the weekend I will see / remember if that .prp is tough to make and let you know. IIRC it was something that I have already done for the post as it is and only needs to be "re-packaged", but no promises made...
  19. #59
    Dec 2010
    Earth
    Try this one. should work. Just make sure to rename it to the same name as the gpp. Let me know.
  20. #60
    Aug 2005
    Netherland
    Quote Originally Posted by jailbreaker View Post
    Dear, can you post the file. Thank you
