Hello,
We are having another problem with our smooth stepper installation in that the watchdog timer gets an error when we pause between job setups etc. Can we simply increase the time for this to allow for slack times between cutting sessions or is there a way to disable the watchdog or is it not advised to disable this??? Might be good to be able to stop the timer when not cutting and restart the timer as a toolpath is initiated? It is not acceptable to have to disconnect the USB and restart Mach every time we get this error, so any help is surely appreciated!
Also the homing has not been resolved and I am wondering if I wire the switches individually if it will work either series NC or parallel NO?
Thanks for any help!
Regards,
Wes
