Results 1 to 3 of 3
Thread: Spindel drive VFD. Setup help please
    Feb 2012
    uk
    Question Spindel drive VFD. Setup help please
    Hi all
    I need to connect my VFD to smooth stepper and not sure how to do it.
    I am using Mach3 control
    Any help greatfully recived
    UUU
    UUU is offline
    Apr 2010
    UK
    You usually need a spindle control board to translate the PWM signals coming down your parallel port (or in your case through the Smoothstepper) into a 0-10V or 0-5V control signal for the VFD, together with the stop-start signals.
    See the PMDX 106 as an example.
    There are some stepper driver systems that are all-in-one and include the spindle control e.g. the well respected Gecko G540.
    Then in Mach3 the PWM signal is controlled on the SpindleSetup tab of the Port&Pins set up page. Also the SpindlePulleys set up.
    Tinkerer
    Nov 2009
    C6 will work
  1. cincinatti hawke 150 spindel drive
    By greg b in forum Cincinnati CNC
    Last Post: 02-10-2011, 07:39 PM
  2. Need Help!- Spindel drive FR-SF-4-11KP
    By FMV in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 11-09-2010, 10:58 PM
  3. Need Help!- ABB Inverter Drive and Motor Setup
    By antsals in forum General Electronics Discussion
    Last Post: 08-04-2010, 07:02 PM
  4. Questions on drive setup
    By elogicca in forum Linear and Rotary Motion
    Last Post: 05-15-2007, 01:33 PM
  5. Need help with servo/drive setup
    By CreativeOffroad in forum Machine Problems, Solutions , Wireless DNC, serial port
    Last Post: 02-21-2007, 01:34 AM
