Results 1 to 2 of 2
Thread: Queations about 24 vdc
    Nov 2006
    I am trying to install a cnc4pc c23 and a ss in an older mill that uses 24 volt dc limit switches and solenoid valves. What is the best way to connect 24 vdc to the SS?
    Steve
    Feb 2007
    canada
    What amp are the solenoids ?
    You can use a 75452 dual driver chip if its under 500ma, or a small reed relay.
    Best to isolate a solenoid, since the inductive kick back may affect SS.
    Manufacturer of CNC routers and Viper Servo Drives
    www.LarkenCNC.com and www.Viperservo.com
