Results 1 to 4 of 4
Thread: Mach3 Plugin for Ethernet Smoothstepper
    Jan 2012
    Smile Mach3 Plugin for Ethernet Smoothstepper
    Newbe Here,
    Surely this has been asked and answered before, but I can't find it.
    Planning to build CNC Router/Plasma Torch cutting table. Most of my computers use Win 7 64-Bit OS. Looking into using Ethernet Smoothstepper with Mach3. There does not appear to be a lot of information about ESS. Do I need a plugin or driver installed on my computer. The plugin's available for Smoothstepper all seem to be for the USB version.
    I am early in the planning so I could use feedback on my choices.
    I have TurboCad Premium and CAM for TurboCAD.
    Yet to look into a BOB, Motors or Motor Drivers.
    Thanks for the Help!
    Dave
    Registered KOC62's Avatar
    Mar 2009
    ESS
    I just got my ethernet smooth stepper. Also haven't hooked it up but is a work in progress.
    I used this info: Untitled 1
    Jan 2012
    Thanks for the help, this is just the information I was hoping to find.
    Look forward to hearing about your project and how you like the ESS.
    I have yet to decide on a BOB, motor controllers or motors.
    Mar 2009
    Smile Ethernet Smooth Stepper (ESS)
    Glad it was useful to you.
    My diy cnc is more of a proof-of-concept since I don't know yet what I want to make with it. I did have a desire for milling PCBs.
    My reason for choosing the ESS was that I had bought a Gecko G540 4-axis controller which has 10 micro-stepping feature. What I didn't realize at the time was that in order to get 100 IPM jog rate the direct drive motor must run at 1100RPM. At this RPM and 10 micro-steps requires a step frequency of 36.7KHZ. Mach_3 might get 45KHZ with my computer. To allow the potential of higher RPM, I decided for a device that could go much faster without pushing Mach_3 to the edge. Hence the choice of ESS which can do 4MHZ step pulse rates. The ESS can fully drive the G540 to its 300KHZ max. pulse rate.
    I also realize that my lead screw may well whip at the higher rates and I did get slight whipping around 1200 RPM using an electric drill for testing. Once you know the limits of each device, you can then assess the limits of performance and know where the "bottlenecks" are. I can live with my current design choices at this point.
  1. CAM plugin or LazyCAM (MACH3)
    By stevenlgts in forum TurboCAD/CAM
    Last Post: 12-05-2010, 11:36 AM
  2. Mach3 + SmoothStepper + G540 = No go
    By CarbonKevin in forum Mach Software (ArtSoft software)
    Last Post: 11-23-2009, 06:09 PM
  3. Mach3 Engraver Plugin
    By bdring in forum General Laser Engraving & Cutting Machine Discussion
    Last Post: 10-06-2009, 07:30 AM
  4. Need help to install plugin to Mach3...
    By jaru-eri in forum General CNC (Mill and Lathe) Control Software (NC)
    Last Post: 03-28-2009, 12:46 PM
  5. Need Help!- SmoothStepper and Mach3 setup
    By jeffmorris in forum Mach Software (ArtSoft software)
    Last Post: 09-02-2008, 04:09 PM
