Results 1 to 3 of 3
Thread: Smooth Stepper
    Nov 2008
    Smooth Stepper
    I just installed Smooth Stepper and I can't individually tune my axis. I need to limit my Z Axis to a lower feed rate. Is this normal behavior?
    I just updated to the newest version of mach3 to see if that helped, it didn't.
    I'm running SS 17d and FTDI 2.08.20
    Dec 2006
    Did you check the Mach3 website and the Warp9 website for this?
    I am not sure where you got your drivers but this is worth reading through.
    Warp9TD Downloads
    It says something about not using the drivers on the FTDI site, to use these.
    Its been almost 3 years sense I installed my SS, and even then it was only bench tested so I cant help you much here. Looks like i have a lot to go through when I fire my machine up myself.
    Jess
    Nov 2008
    Ah, yeah I'm running the latest versions from that page. See I posted them in my original post. Thanks anyways.
  1. mach3 cv and smooth stepper
    By Montabelli in forum Mach Mill
    Last Post: 01-30-2010, 10:38 AM
  2. Smooth stepper
    By dnelso in forum Industrial Hobbies (Support forum)
    Last Post: 08-04-2009, 12:07 PM
  3. smooth stepper setup
    By eloid in forum DIY CNC Router Table Machines
    Last Post: 06-05-2009, 08:32 PM
  4. What is a Smooth Stepper and ...
    By gotfdirtball in forum Mach Software (ArtSoft software)
    Last Post: 03-16-2009, 08:43 PM
  5. Smooth Stepper and resonance
    By IQChallenged in forum Machine Problems, Solutions , Wireless DNC, serial port
    Last Post: 05-26-2008, 08:30 PM
