Results 1 to 3 of 3
Thread: Smooth Stepper Advice please
    Registered Mad Welder's Avatar
    Jun 2011
    Ireland
    Smile Smooth Stepper Advice please
    Hello CNC enthusiasts,
    I am new to this website, and ha… new to forum blogging (if that’s the correct wording) too, and please excuse me if I have posted in the wrong link.
    For any other new CNC enthusiasts and new forum users too, see the links below for good starting places to work from, unfortunately I don't know how to insert links yet but if you copy the link and paste into your browser it will work.
    I don’t have a parallel port on the PC I want to use to run Mach3 for my project so, I am looking for advice on usage of the Smooth Stepper from Warp9.
    http://warp9td.com/documentation.htm, by Warp9 http://www.warp9td.com/ these are also supplied by Keling and by CNC4PC and I assume by many other suppliers.
    I would like to hear feed back on potential problems if any with configuration of the Warp9 software/hardware?. I intend to purchase my package from CNC4PC as from looking at discussions I believe they provide good after sales service and support.
    Am I correct with my hardware configuration setup as follows; PC/Eithernet or USB cable/Smooth Stepper connected directly board to board to the C32 Beaker Board http://www.kelinginc.net/C32Manual.pdf and using the on board connection blocks RJ45 connectors for all I/Os and as CNC4PC suggest you only have to use standard networks cable to make all connections. These I can directly connect to the respective Digital Stepper Drivers with the addition of C34KL - Driver to RJ45 Connector Board http://www.kelinginc.net/BreakoutBoards.html.
    There is another fantastic website http://www.g0704.com/index.html where loads of additional information can be accessed, and thanks to them I am using part of one suggested CNC hardware conversion configurations for my project.
    Regards,
    Eoin.
    Eoin
    Mar 2003
    Shelby Twp, MI....USA
    Am I correct with my hardware configuration setup as follows; PC/Eithernet or USB cable/Smooth Stepper connected directly board to board to the C32 Beaker Board http://www.kelinginc.net/C32Manual.pdf and using the on board connection blocks RJ45 connectors for all I/Os and as CNC4PC suggest you only have to use standard networks cable to make all connections. These I can directly connect to the respective Digital Stepper Drivers with the addition of C34KL - Driver to RJ45 Connector Board CNC Break Out Board, CNC router.
    Ethernet is not used. If you don't use a Smoothstepper, you need to use a parallel port.
    It would appear to me that the C34KL may only work with certain drives that have matching pin locations.
    But yes, for the most part, you are correct.
    Jun 2011
    Ireland
    Many thanks for the reply Gerry
    Eoin
  1. Smooth stepper
    By dnelso in forum Industrial Hobbies (Support forum)
    Last Post: 08-04-2009, 12:07 PM
  2. help on smooth stepper ....is it dead
    By the4thseal in forum Mach Software (ArtSoft software)
    Last Post: 07-13-2009, 05:29 PM
  3. What is a Smooth Stepper and ...
    By gotfdirtball in forum Mach Software (ArtSoft software)
    Last Post: 03-16-2009, 08:43 PM
  4. Smooth Stepper and resonance
    By IQChallenged in forum Machine Problems, Solutions , Wireless DNC, serial port
    Last Post: 05-26-2008, 08:30 PM
  5. how to smooth out stepper operations
    By phantomcow2 in forum General Electronics Discussion
    Last Post: 10-21-2005, 09:01 PM
