Results 1 to 3 of 3
Thread: Driver Installation Problem
    Sep 2006
    Running XP Pro. Have SS and PMDX-126 BOB. When going through the 'New Hardware' routine while installing driver up pops the message - "The file 'ftdibus.sys' on FTDI Disk is needed." I'm unable to find file. How do I solve? Help!!!!!!!!!!
    Registered doorknob's Avatar
    Jan 2010
    Would this page help?
    FTDI Drivers
    Sep 2006
    Problem solved. Basically had to uninstall/delete everything and start over. Greg at Warp9 was of great help. Here's what he sent me and it worked. Maybe it will be of help to someone else if they need to update driver.
    You should be able to find a browse button and point it to the directory
    where the driver files are located (where you unzipped them to).
    If that does not work, I would try going into the Device Manager and
    locate the SmoothStepper (it should be plugged in). You might find it
    under "Unknown Devices" or the USB devices. Wherever you find it,
    right-click on it and choose to either reinstall or remove the remove
    it. That will give you the opportunity to start over (if you remove it,
    then you will need to unplug it and plug it back in again).
    If that doesn't work, then you should run the following program from
    FTDI (be sure to unplug the SmoothStepper first):
    http://www.ftdichip.com/Support/Util...aller_v1.4.zip
    There is a command-line version and a graphical version. I would run
    the graphical. Here is a link to the readme for the graphical version:
    http://www.ftdichip.com/Support/Util...UI_Readme.html
    You will need to enter "0403" for the Vendor ID, and "A650" for the
    Product ID (don't include the quotes, and be sure that the "A" in "A650"
    is capitalized).
    Click Add.
    Then click "Remove Devices" and it will remove every instance of a
    SmoothStepper from your system. Plug in the SmoothStepper and you
    should be able to install it properly.
  1. plugin installation problem.
    By draughted in forum SmoothStepper USB Motion Control
    Last Post: 06-04-2011, 01:30 AM
  2. Problem- TM 2x2 driver problem - wants to put 64 bit driver in ???
    By ronsii in forum Torchmate
    Last Post: 12-27-2010, 05:10 PM
  3. Galil 1740 installation problem
    By python01 in forum Controller Cards
    Last Post: 07-04-2008, 11:02 AM
  4. Mach2/Mach3 installation problem (laptop)
    By xyz100 in forum Mach Software (ArtSoft software)
    Last Post: 07-25-2006, 09:56 AM
  5. Installation problem
    By aem_argentina in forum Solidworks
    Last Post: 03-21-2006, 12:19 PM
