MB2 and wiring up limit switches and estop
Results 1 to 5 of 5
Thread: MB2 and wiring up limit switches and estop
    Dec 2016
    Default MB2 and wiring up limit switches and estop
    Just wiring up the MB2 and I"m a little confused on how to wire in the limit switches. Would it make sense to wire each axis to it's own input? So would use 3 inputs for 3 axis. Wire the e-stop to X203 (which comes pre soldered on back of board). So If I used the 3 inputs below X203 would I then solder there inputs together on back of board to create the safety circuit? But if I used the limit switches as home switches then I would not solder the backs as I would not want to create an estop when homing correct?
    Member ger21's Avatar
    Mar 2003
    Shelby Township
    Default Re: MB2 and wiring up limit switches and estop
    There are probably 100 different ways to do it, and it really depends on how you want to do it.
    Whether you wire them to separate inputs or one input really doesn't make any difference at all. The software won't know which switch was tripped regardless.
    The question is do you want do you want the limit switches to do? Do you want them to kill power to everything, or just tell the software that a limit has been tripped?
    The safety circuit doesn't really do anything, unless you set up all of your components to properly use it.
    UCCNC 2017 Screenset
    Dec 2016
    If I wire up each limit switch individually to an input then the software (Mach4) should know which one gets tripped. Since I have lots of inputs I was going to do it this way. I figured this would help with diagnostics too. So I'm guessing in the software I could tell Mach4 to either trip the estop or not trip the e-stop based on which input gets triggered?
    Mar 2003
    Shelby Township
    Do you know that Mach4 can do that? I'm not that familiar with Mach4's capabilities.
    Jun 2005
    YES, Mach4 can do that if they are wired to individual inputs. The question is can you spare that many inputs for just limit switches. More common to tie all the limit switches in series and run to one input. There are ways to wire up LEDs on each limit switch to highlight which one is active, but if you are using Limit Switches as a Home Switch as well you must wire them to individual ports.
    Russ
