Problem USS Smoothstepper and USB Keyboard Don't play together
Results 1 to 2 of 2
Thread: USS Smoothstepper and USB Keyboard Don't play together
    Mar 2006
    Default USS Smoothstepper and USB Keyboard Don't play together
    Hi All,
    I am having a problem with a new build with a USB smoothstepper and a USB keyboard/mouse. The mouse and keyboard work fine at all times even in Mach 3 with "No Device" but do not work if I start mach 3 with USB smoothstepper. I tried a totally different mouse and keyboard with the same results. Does anyone know what could be causing this?
    Thanks,
    Max
    Mar 2006
    Default Re: USS Smoothstepper and USB Keyboard Don't play together
    Solved,
    I bought a bunch of new USB cables and a bunch of new USB Hubs. The computer only has 2 USB Ports so the USS Smoothstepper to one with a new cable and the keyboard, mouse, and a port for flash drives to the other through the hub. All of the cables and hubs were the problem. Finally, I used an old hub and old cable I had laying around and no more problem.
    Max
