ESS running a stepper motor as a spindle
Results 1 to 2 of 2
Thread: ESS running a stepper motor as a spindle
    Feb 2008
    Default ESS running a stepper motor as a spindle
    I have a problem that I cannot get the ESS to run a stepper motor as a step and direction spindle.. I cannot get the ESS to put out a continuous stream of pulses by an M3 S300 command. Surely the ESS should be capable of running a step and direction spindle. There is even a box for that in the ESS config file. So can you just check that function to see if you can get a spindle to use the m3 command using step and direction?
    A few minutes ago I set up a G540 with a stepper motor using the parallel port and verified that Mach3 does run a stepper motor continuously as a spindle using step and direction. Any help would be appreciated.
    Dan Mauch
    Oct 2010
    Default Re: ESS running a stepper motor as a spindle
    I have the same problem. Running Mach 3, ESS with CNC4PC board C52. I cannot get any pulses from the smoothstepper on the designated step and direction pins. Any help would be most appreciated.
