Results 1 to 2 of 2
Thread: Look at this cycle L930 and please help me understand
    Registered cnc_swe's Avatar
    Jan 2006
    sweden
    We are talking Sinumerik 810M and the cycle L930 a circular pocket.
    I like the simple way to make code via dialog but this time I don't understand
    whats going wrong.
    Output State is as follows:
    The end mill 5mm (2.5mm in registers as radius call D5)
    G90 G17 G41 D5 F150 G94
    G00 G54 X0 Y0 Z5
    G00 G55 X0 Y0
    G00 Z-2
    N30 D5 G41 M03 M08 S1500 F200
    N40 R1=3 R2=-1 R3=-9 R6=2 R15=250 R16=50 R22=0 R23=0
    R24=3 L930 P1 (R24=3 it is the Radie)
    N50 G55 G00 M08 X0 Y0 Z0
    N60 G54 M05 X0 Y0 Z10
    N70 M30
    L930 is a circular pocket and this is perfect on his first lap with 3mm deep. When the end mill will return to center drill the 3mm down again and start a new circle, BUT this time taking endmill a path similar to an eight. Half of eight, going beyond the one I made earlier. I get the impression that the tool compensation has expired.
    If I let the parameter R24 = 30, both of the pockets to work perfectly.
    This is consistent on all the tools in the registry, so I assume that the error
    should be in the code.
    My machine is a Sinimerik 810M. Why not try in your machine or if someone can figure out what is causing this error.
    Ofcaurse I can CAD/CAM and use the code whitout any error but I like the simple way to get code via DIALOG.
    If any like to se the second way the endmill was going I can make an simple
    pictures in Paint.
    Jun 2011
    bavaria
    Thats normal, in the finish cutting part, the tool makes only the last 1/10 or what you have for finish cutting addition. Instead that, you should better call the rough cycle again, but with the complete depth in one cut. Sorry, I use the 840D and don't know, whats the meaning of all the R-parametres. I use regularly the Cycle 2 times, in the first I make only the roughing and eventually, if the Pocket is really deep the parted depth finish cut. After that I call the same Cycle again, with a depth of 1/10 deeper without the finecutting addition.
  1. Newbie- G84 Tap Cycle.
    By neilthib in forum Fadal
    Last Post: 12-19-2011, 12:43 AM
  2. CYCLE 83: pecking cycle with deepened starting point
    By Bastida in forum Siemens Sinumerik CNC controls
    Last Post: 12-18-2011, 10:25 AM
  3. Heidenhain iTNC 530: Using Cycle 19 and Cycle 8
    By Dan B in forum General CNC (Mill and Lathe) Control Software (NC)
    Last Post: 08-27-2011, 12:32 PM
  4. Need Help!- How to use G73 Cycle ?
    By pintusharma in forum Fanuc
    Last Post: 12-28-2010, 02:41 PM
  5. G76 CYCLE
    By BAD DOG in forum General Metal Working Machines
    Last Post: 09-20-2008, 05:33 PM
