Results 1 to 2 of 2
Thread: Radius vs Diameter program reading
    Jan 2011
    Hi guys,
    Sorry to bother. I have another question about the Fryer ET-30BB Lathe with a Siemens control (with Shopturn 7.50.18.00). Parameters are the same as a 840D control.
    We are trying to make the machine read the G-codes in Radius rather than in diameter. We tried changing parameters
    9611 $MM_CTM_CROSS_AX_DIAMETER_ON
    9619 $MM_CTM_G91_DIAMETER_ON
    to make the program read programs in radius. For G91 (incremental), it does read in radius. The problem is that we cannot make the program read X value in radius for G90 (absolute), all we can do is make it display in radius and it will keep reading the program in diameter.
    Anyone would know what to change to make the program X value in radius in G90?
    Thanks!
    Jan 2011
    Solution found
    All was needed was to write DIAMOF in the G-code program. I found this in programming manual.
    Thanks.
  1. Need Help!- Parameters 18i lathe radius to diameter
    By VIDE in forum Fanuc
    Last Post: 08-18-2010, 08:11 AM
  2. Lathe Diameter or Radius
    By davidperry3 in forum Tormach Personal CNC Mill
    Last Post: 12-24-2009, 12:18 PM
  3. Are lathe offset values on radius or diameter?
    By sinha_nsit in forum Fanuc
    Last Post: 11-06-2009, 09:46 AM
  4. From Radius to Diameter Programming
    By metx in forum Fanuc
    Last Post: 04-10-2008, 02:04 PM
  5. VisualTurn diameter v/s radius mode
    By whiteriver in forum Visual Mill
    Last Post: 05-10-2006, 12:56 PM
Visitors found this page by searching for:
Nobody landed on this page from a search engine, yet!
SEO Blog
