Botha.y
you need to make sure you select the Z axis in the upper right hand corner of the screen. use the Axis + / - buttons to select. the parameters will still be 36100 and 36110. you only see one axis at a time. 36120 and 36130 are optional parameters not being used. hope this helps.
LinkBack URL
About LinkBacks
