your machine has emergency. you must control emergency line.
and if dont work panel soft key you check connector between hmi plastic panel and hmi metal case.
I have old Reichenbacher ranc210am router with Siemens 810M controller. It was powered year ago then left. Now I'm trying to move it again. First problem is that Emergency stop release button light is on and I cant extinguish it, no button from that panel (Reichenbacher) show any respond only light test button. Second, almost all buttons from siemens panel do not respond, those which respond do different function than it should. Here is controller photos ImageShack Album - 2 images
Go to PROGRAM softkey, then press DIRECTORY.
Look for any program inside.
If no programs in the memory, the control donīt have machine data.
Can you post a better photo for the screen MANUAL?
I think that controller lost it program because of dead battery. This is video of controller [nomedia="http://www.youtube.com/watch?v=bZoU-pgUJWY"]YouTube - 100_7309.MOV[/nomedia] Now I searching for cable, think RS232 should do.
I don't have backup program, but I working on that. Is there more tutorial like installation instructions than this?
https://a248.e.akamai.net/cache.auto...structions.pdf
I found cheap RS232 cable Pin25:M - Pin25:M 1.8m LEMONA - Elektronikos dalys , and noticed that old computer motherboard has such connection for printer. It is possible to make connection with this?
how much money do you pay ?
