Hello all, This is Engineer Ayman From Egypt
I have a new center machine worked by siemens system
The problem is the Y-axis make a high noise during operation or if i try to move it by handweel, when I operate it I find it’s noise is hard and rough then the machine stop and the alarm No. 25080 appear
I took off the motor of Y axes from the machine and the system control it directly without any load there is no alarm also I lubricate the guide and screw guide and i can turns it smoothly but the problem still accrue,
If anyone have an idea for how to recover this problem, please don’t hesitate to reply me
Thank you
Hallo Aymancom 1,
Well I´m not the right man to answer the question but if you read cnc_viking on this site maybe it can help you a bit on the way.
http://www.cnczone.com/forums/mazak_...oud_noice.html
