Results 1 to 4 of 4
Thread: CNC RETROFITTING
    Jan 2011
    India
    Exclamation CNC RETROFITTING
    We have 6-axis wotan horizontal milling & boring machine.
    Linear axis- x,y,z,w & U.
    Rotary table B Axis
    Z,U & W axis are parallel.
    Z is tool axis.
    X is cross slide.
    We wish to retrofit the machine.Which control I should select & also suggest How many axis simutaneous control for linear & circular interpolation.
    Feb 2011
    Siemens 840D SL is the ideal control for this retrofit application. You can keep the existing motors and drives if they are in good working condition and just change the CNC and PLC part of the machine.
    We sell and support Siemens Sinumerik products.
    Dec 2003
    I would also look at Fagor, they have units which are up to the task.
    Apr 2003
    should try the latest low cost siemens 808d made by siemens in china!!
    that should cut lots of juice esp at these times.
  1. Retrofitting a control
    By carbidecraters in forum Fadal
    Last Post: 07-23-2007, 10:44 AM
  2. Retrofitting a Beaver NC5
    By IN-WondeR in forum General Metal Working Machines
    Last Post: 06-20-2007, 09:56 PM
  3. Retrofitting a Bridgeport
    By kuchean in forum Servo Motors and Drives
    Last Post: 07-24-2006, 02:46 PM
  4. Retrofitting a Mazak HMC
    By jorgelr in forum General Metal Working Machines
    Last Post: 06-01-2006, 12:16 PM
  5. Knee retrofitting
    By m_c in forum Knee Vertical Mills
    Last Post: 02-27-2006, 04:12 PM
