Results 1 to 4 of 4
Thread: 6RB20 SERVO SYSTEM NOT READY
    Registered erdinct's Avatar
    Feb 2009
    Turkiye
    servo system voltage opening and V155 green led is on. after 63 and 64 input when "1" V155 green led is off. and V156 red fault led always off. on the axes cards V318 led's off but K27 ready relay not working.
    Don Diegoo
    Aug 2006
    Iran
    6RB20
    Quote Originally Posted by erdinct View Post
    on 6RB system there is one board as power supply G0 - on this board there is Green LED , that means power ready but not enable , after enable happen ( 63-64) if every things ready no LED must be light up .
    try to put a low volt in 56-14 such as 0.5 volt DC and check what happen ,..
    check motor and cable , check the resistor between power board N1 ...Nn
    and let me know what kind of control and machine yo have problems
    clean up all board and retide all connection on this modles of siemens drive always use full ,
    i need more information on this fault , then i can help you , whats the control alarm ?
    Nov 2006
    Poland
    Feb 2009
    Turkiye
    ok thanks so much. we changed power supply unit and problem is gone..
  1. Siemens 6RB20
    By gridley51 in forum Siemens Sinumerik CNC controls
    Last Post: 04-27-2011, 05:34 AM
  2. 3 Servo Motors - Ready for CNC work.
    By JohnnyVegas in forum EBAY ADS
    Last Post: 02-24-2010, 12:15 AM
  3. System variable for tool in ready position
    By Dana099 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-20-2007, 04:30 PM
  4. Which Ready Built CNC Milling System Would You Buy?
    By antsals in forum Benchtop Machines
    Last Post: 10-11-2006, 07:57 AM
  5. Getting ready to buy a Flashcut 4400V Servo
    By mts in forum FlashCut CNC
    Last Post: 03-11-2004, 01:59 PM
