Page 2 of 3 FirstFirst 123 LastLast
Results 13 to 24 of 26
Thread: sinumerik 810M error #12 - PP memory wrong format
  1. #13
    Registered vavco's Avatar
    Mar 2008
    Slovakia
    well, I set transmission parameters as they are recommended once again
    and now it has worked - I could upload and download as well . I do not know
    what exactly happened because I had the same before and it worked only one way .. ?? as to the timeout , I left it in 4s.
    However , even if I can turn the machine on, do reference points, move with axes in every direction ( I had to set some parameters in AXIAL data window, because sometimes it did not go to + , sometimes to - directions ) I still have a problem to run the machine in Automatic mode. A guy who works with this machine uploaded some working program ... but after pushing a button for auto start - nothing happens . So , I think I'm stuck in some point and do not know what to do now.
  2. #14
    Jul 2010
    Argentina
    First , you need load the standart machine data from the Service screen, then, format the memory areas, and then, load the TEA1, format user memory, alarm memory and user memory from the Service screen.
    After that, you can load TEA2 , PCA , PCP.
    If you dont do that in these order, you canīt load data because the system donīt have the memory in order.
    For upload data, you can use PCIN in old DOS OS, or WINPCIN for Windows.
  3. #15
    Mar 2008
    Slovakia
    I think, I did all in the order yaesu747. PCIN also works under XP , I used usb-serial converter to make a transfer. Now, I have a problem to start the machine in auto mode.
  4. #16
    Registered cnc_swe's Avatar
    Jan 2006
    sweden
    Need to restar Sinumerik system
    In Sinumrik you dont find any F5 to restart. If you replay a new parameter ex, N5 000010100 yuo must restart Sinumerik a again.
    Please send pictures from you screen when you got probleme.
    It is mutch simple to me and other gay to understand the error.
    I most going to sleap. But Good luck
  • #17
    Nov 2010
    Pakistan
    Awais
    Quote Originally Posted by cnc_swe View Post
    I translated the error "wireless communication". I meant RS232 (V24 serial.)
    You need a simple terminal program like Windows HyperTerminal or any application where you can put your parameters for RS232 transmission.
    The last software should be in the PC to fill up the text file you get from me to be in Sinumerik.
    All data bits I got in the previous example, you must login on the Sinumerik first and write some communikation data.
    ex: 5012 = 0000 0000 Whether you must manually write or download via RS232.
    First of all you must enter the MACHINE DATA BITS in Sinumerik.
    Next, find the menu in Sinumerik as I/O On this menu you will find Transmitt or recive file.
    If both of the terminal have same data ex: RST, 7, 1200 baud, Non, 2stop the communikation can start between computer and Sinumerik.
    You may enter any parameters manually, but there are several hundred.
    Try to read your manual how to edit this database.
    Trying to get data from another machine instead of from a PC based on the same idea but then you will be able to manage the RS232 also in the machine.
    I can send the owner's manual in English if you want.
    I have a turret punch cnc machine .It was working properly last night.At
    next day when i turned it ON than there was a low voltage battery alarm
    at screen .Than I replace the batteries and turned OFF machine So Turned ON again .At this time low battery alarm had released but another alarm occured.
    at the screen "3 PLC STOP"
    Can any one help me that how I can release this alarm and machine data is
    save or not.All drives are of Siemens Sinumerik.
    I will be great thankfull to u
  • #18
    Nov 2010
    Pakistan
    Dear
    Machine specification:
    RT.210.12
    N- 6037- Nr
    Mfg- 1996
    400v Ac 50 HZ
    26KW 50A
  • #19
    Nov 2010
    Pakistan
    3 PLC Stop How can reset it
    Dear
    How can I reset Alarm
    3 PLC Stop
    Please help me I need your help
    E=cnc_swe;807687]this guide is from Siemens book/file
    SINUMERIK 810
    SINUMERIK 820
    Basic Version 3
    Software Version 2
    Installation Lists
    Installation Guide 01.93 Edition
    7.1.1 POWER ON alarms (No. 1 ... 56) POWER ON alarms can only be reset when the control is switched off and on.
    Alarm No. Meaning
    1 Battery alarm - power supply R
    2
    3 PLC Stop
    4 Incorrect unit system
    5 Too many input buffer parameters
    6
    7 EPROM CHECK error
    8 Wrong axis/spindle position
    9 Memory too small for UMS
    10 UMS error
    11 Wrong UMS identifier
    12 Part program memory wrongly formatted
    13 RAM error on CPU
    14 RAM error on memory module
    R The error is not program-specific so it is only given an ORD number
    (ORD 10 means that this is the 10th error after Power On).[/QUOTE]
  • #20
    Jul 2011
    egypt
    hello all
  • #21
    Jul 2011
    egypt
    pls i need your help vere important i have sold cnc router 5 heads machine from italy from 1 week siemens 810m and i need to send any nc file from my computer to the machine
    but i have somthing wrong i am doing it now look in the catalog and write in the parameter and i have proplem for set the cable with the machine mabey somthing wrong i am set parameter in the 1200 budrate from 5010 to 5014 pls i need to send any thing from my pc to this machine pls any body help me and you have to know lang of the machine is italy can help agine for change the lang to english ?
    first : send data to machine from my pc ?
    2 : change lange to english ?
    thank you all
  • #22
    Mar 2008
    Slovakia
    Hi hosamsoft , send your email , I will try to collect any info that I have got in my computer and send to you. I did solve my problem a long time ago , so I do not remember what I did exactly. Anyway , I can send you PCIN software and there is wire layout for a cable in the part of menu . I used, I think 25 - 9 pin cable . As to in/out devices , parity , stop bits and baudrate :
    5011 11000100
    5012 0
    5013 11000100
    5016 00101000
    cable 9 pin 25 pin
    1 shield 1
    2 2
    3 3
    4 6
    5 gnd 7
    6 20
    7 5
    8 4
    good luck , vavco
  • #23
    Sep 2010
    Please forgive my forward approach, but I've recently acquired a CHNC-1 and with it came a CD containing PCIN version 4.43. The problem is, I have a new 64-bit laptop and this program won't run in a 64-bit environment. I need an update from someone.
    Assuming the newer WINPCIN version is 64-bit compatible, could I impose on any of you to provide me with a copy?
    Alternatively, I wonder, have any of you tried a standard COM-port transfer program, or does the Siemens controls use a proprietary transfer protocol?
    Torin...
  • #24
    Mar 2008
    Slovakia
    Hi Torin ,
    as I remember I could download or upload files in 3 ways ( by using PCIN 4.43 or PCIN 4.2 ) : 1. old laptop with serial 9 pin PORT ,PCIN under MS DOS 2. the same laptop under XP 3. laptop with USB port , XP and a USB/RS232 converter .
    1. & 2. cable 25 PIN (sinumerik) -- 9 PIN (laptop)
    3. cable 25 PIN (sinumerik) -- 9PIN cable -- 9 PIN (RS232 converter IN) --- USB mini (converter OUT ) --- USB (laptop)
    So , if you get the converter that works with 64 bit driver it could
    probably work .... but this is only my idea .
    Take care , Vlado
  • Page 2 of 3 FirstFirst 123 LastLast
    1. Sinumerik 810M - error 2087
      By hartan in forum Siemens Sinumerik CNC controls
      Last Post: 01-02-2011, 06:09 AM
    2. memory sinumerik 3n
      By klinkcnc in forum Siemens Sinumerik CNC controls
      Last Post: 04-14-2010, 05:33 PM
    3. Need Help!- Siemens 810M 1720 ORD + X error (Motion Master Router)
      By mjhjenks in forum Controller & Computer Solutions
      Last Post: 03-02-2010, 05:06 PM
    4. SINUMERIK 810M GA1
      By amo in forum General Electronics Discussion
      Last Post: 11-17-2009, 03:58 AM
    5. Sinumerik 810m ga2 ram module battery question
      By jgriffith66 in forum General Electronics Discussion
      Last Post: 11-26-2007, 02:39 PM
