Good Morning forum
Below is our Yasnac probing from our Matsura Vertical mill
N10T10M6
M00(LOAD INDICATOR)
G43G54X0Y0Z4.H10T1
M00(TRAM PART G54)
G49G53Z0
#2501=#5021
#2601=#5022
#5227=[[#2502-#2501]*90]
M00(REMOVE INDICATOR)
N1T1M6S3000(1/2 CARBIDE ENDMILL .015R)
We have since moved the job to our Matsura ES1000 Vertical mill with Siemens 840 Di control
We are tramming a timming pin and setting G55 X and Y zero, Loading the part and Probing the ctr at G54 X0 Y0 that is Y-.640 but there is a bit of rotational deviation between the 2 positions we then calculate and rotate the axis to align G55 and G54 for vertical alignment between G55 and G54 to hold Tru Position call outs From the Timming Pin to holes we are installing.
I believe we should be able to use a CROT command?
