- New Machine Build- A small CNC Turn Mill Centre with Aluminium Structures
A small CNC Turn Mill Centre with Cast Iron Structures like Slides/Bed Weights 700kg. Can Aluminium material be used in place of Cast Iron for the Structures?
Machine is used for light machining, feed rates are limited to 6 m/m, max. spindle speed is 6000 rpm. Positioning and Repeatability accuracies are 20microns and 10microns. Components turned on this machine is expected to be IT 7th quality.
- You may not post replies
- You may not edit your posts
Forum Rules
