- 808d 1325 Milling CNC - Looking for PLC
So I have an 808d with a 3 axis milling macine with an ATC but the machine is not yet commissioned and I need the PLC written. I have been told however if I can find someone with roughly the same config, it will be easy to copy their PLC. Any help is greatly appreciated.
Re: 808d 1325 Milling CNC - Looking for PLC
You might try posting on the Machinist page on Facebook: https://www.facebook.com/groups/Machinist/
While the group can be a bit.... rough... there's also a lot of REALLY good guys on there... altho with 98k+ members, there's a fair share of asshats, but you can just ignore them. There hasn't been ANY problem yet I've had where at least one person was able to help me with a solution.
I will not work! you have to find la PLC programmer to help you with that
- You may not post replies
- You may not edit your posts
Forum Rules
