- HMI Embedded network controller
I have a Siemens 810D controller on my 2008 CNC machining centre. I have it networked to a pc in the office and have been sending programs to it from the CAM system ok via the HMI embedded network controller. I recently got a broadband connection in the office and connected the pc to the internet via a wireless. Now the machine will not see the network drive. I have gone through every thing with the machine manufacturer and all checks out as it should be. The only thing that I can see that is different is a small blue and yellow shield on the icon for the HMI embedded in the start menu of windows 7 that wasn't there before. If I right click the icon and select run as administrator it puts the small icon in the right of the task bar as normal but it still will not let the machine access the network drive.
Any ideas?
- You may not post replies
- You may not edit your posts
Forum Rules
