Hello,
The M function for the pallet changer is M71.
Regards
Thomas
Hi everyone
Recently we purchased used chiron fz12w with sinumerik 810m ga1 twin pallet german language
My question is that i do not know how to change pallet is there any m code or special procedure for pallet changing
2nd question when we type a command in automatic section or part programming , i write command and when i hit the enter button control freeze and do nothing
I tried reorg commsnd to reorganize part program memory but also system freeze with the alarm "reorg activ" but anywhere i can use this enter button and give the command to control like overstore but freeze in mdi and part program section
Thank you
Hello,
Regards
Thomas
I know it's several months later, but I just found this. There are codes for each pallet. M31 calls pallet 1 under the spindle and M32 calls pallet 2.
Hi Milan
can you provide a MachineNumber.
Regards
Thomas
