- Sinumerik Operate- Alarm 12661
Hi all,
When executing a subroutine which is called on countless occasions, the next alarm goes on one of these occasions:
Alarm 12661: Technology cycle _syncro: No other subprogram call is possible. (_sincro is the name of the surutine defined as PROC)
What are technology cycles? How can I avoid the alarm? What limits does a subprogram have at the time of being called? And if said subprogram is defined as PRORC?
Thank you very much!!
Re: Sinumerik Operate- Alarm 12661
I still don´t know how to fix it, but apparently it has something to do with synchrnous movementes or with call limits on a PROC SUBRUTINE. Thas limit should be removed.
- You may not post replies
- You may not edit your posts
Forum Rules
