So it seems to be a battery issue, not overheating.. its a bad translation.. So the machine had dropped all parameters as well.
So i bought this old Storebro Combi Mill CNC. and it comes with Siemens Sinumerik 810M GA3.
But when it boots the fans go on and all that. But no buttons responds, if i press the button corresponding to "PLC Init" it just punches out 1 on the screens lower corner. No character is on a corresponding button.
You cant make it jog or anything or access menus. The ORD1 saids "Overheated" and a red diod lights up. And that all i can do with that.
If anyone has something i can try before i scrap this it would be greatly appreciated.
substitua a bateria antes de começar a passar pelos parâmetros
Did you get the back up with the machine
Yes he did, he described it on the Madmodders forum:
https://madmodder.net/index.php/topic,11351.0.html
Andrew Mawson
East Sussex, UK
