Chiron FZ12W High speed Siemens 810m error codes
Results 1 to 15 of 15
Thread: Chiron FZ12W High speed Siemens 810m error codes
    Jun 2011
    Default Chiron FZ12W High speed Siemens 810m error codes
    Hello everyone,
    Sorry if this is in the wrong forum, but I'm in need of help figuring out what some error codes mean
    I've looked at the operation and programming manual (http://support.automation.siemens.co...edownload=true) but it isn't exactly enlightening. What it says is that alarm 8, 13 and 1080 only happen on commissioning, alarm 3 needs a service technician and alarm 2000 is the only one with meaningful information:
    Reason:
    The EMERGENCY STOP signal is output from the PLC to the NC
    Effect:
    Inhibiting of NC START
    – Operation is brought to a defined stop
    – Servo enable is removed
    – Follow up operation
    Remedy:
    Check to see if the EMERGENCY STOP cam was traversed to, or if
    the EMERGENCY STOP switch was operated"
    Alarm 2000 should be a simple fix I think. Just checking all the switches on each axis plus maybe a few others.
    The original cause of the problems is that the machine got connected to 440V and it's only rated for 220V.
    Any suggestions.
    Thanks,
    Feb 2009
    Ya smoked the memory/Cpu.
    Jun 2011
    Sounds like it could be expensive.
    It's a good thing I have committed to buying the machine.
    Jun 2011
    Anyway to tell if it's the memory or CPU or is it pretty much guaranteed that they are both fried? Do you think that replacing those would fix the other alarms?
    Feb 2009
    Well, PLC stop and Emergency stop would make sense if the CPU and memory is gone. Problem is, you really cant test drives and such until you get that fixed. Maybe a lot more damage than meets the eye. You probably need someone more familiar with Seimens, those arn't popular in the US.
    Nov 2006
    Scotland
    Each thing will need to be checked through.You have a screen up so can`t be fatal.
    You need someone capable to go through it.The drives can be tested independently with a battery box which is standard procedure for commissioning the machine anyway.
    Probably Siemens 6SC610 drives on that machine.
    I`ve got a Chiron FZ12S with 810 control.They are quite simple machines.
  7. #7
    Jun 2011
    I just heard back from Chirons Siemens tech and he's saying that the machine just needs the original parameters and settings loaded. I'll be testing the drives later this week hopefully.
  8. #8
    Mar 2008
    Argentina
    You have to cahnge the battery and reload all parameters. You need %TEA1, %TEA2, %PCP, %SPF, and %ROA,Start loading this files, If you can't maybe you have a hardware problem.
    Carlos
    Quote Originally Posted by efret View Post
  9. #9
    Jan 2013
    Iran
    I need Chiron Fz12 NC Parameter an PLC program.
    Thanks.
  10. #10
    Apr 2013
    India
    Default Re: Chiron FZ12W High speed Siemens 810m error codes
    Hi friend Alicnc,
    Are you having the chiron machine NC and PLC backup.
    Last week machine parameter lost due to battery problem.
    CHIRON FZ12W MAGNUM HIGH SPEED
    SINUMERIK 810M GRAUNDAUSF3
    MANUFACTURE YEAR 1997
    Regards,
    Dhina
  11. #11
    Mar 2015
    hi folks
    i have fz12w 810m ga3 chiron because of dead battery i lost all parameters i found tea1 tea2 but i need pcp file if anyone can help ill be appricated
    thanks all.
  12. #12
    Member tld70's Avatar
    Aug 2009
    Stockach
    Quote Originally Posted by hkdman View Post
    hi folks
    thanks all.
    Hello,
    please give me more infos, I can help you
  13. #13
    Member Machineit's Avatar
    Mar 2010
    Quote Originally Posted by tld70 View Post
    Hello,
    Over two year old post!
    Two Haas VF-2's, Haas HA5C, Haas HRT-9, Hardinge CHNC 1, Bother HS-300 Wire EDM, BobCAD V23, BobCAD V28
  14. #14
    Jan 2013
    Hi, do you have parameters for Chiron FZ12W High speed 1996 Siemens 810m GA3? Thank you
  15. #15
    I have same problem.. need parameters for Chiron FZ12W.
    mlisica55@gmail.com phone +38766284310
