Go Back   CNCzone.com-The Largest Machinist Community on the net! > MetalWorking > Welding, Brazing, Soldering, Sealing
Welding, Brazing, Soldering, Sealing Discuss Welding, Brazing, Soldering, Sealing technique's here.
Old 02-09-2010, 09:42 AM
Rekd's Avatar
Rekd Rekd is offline
Rekd is on a distinguished road
Orbital Vibration Welding or Another Method?
I'm trying to weld stranded wire to a Honeywell thermal switch (over-temp safety switch).
Can't solder it. Can't spot weld it. I've heard orbital vibration welding might be the way to go, but don't have much info on it.
Also, what are battery packs welded with? The connectors to those are much less delicate than what I'm trying to weld, so what ever they're using might work for the thermal switches.
TYIA.
Matt
San Diego, Ca
___ o o o_
[l_,[_____],
l---L - □lllllll□-
( )_) ( )_)--)_)
Tags
orbital vibration, thermal switch, welding
[IMG] code is Off
Need Help!- Orbital Drilling Mohan General Metalwork Discussion 11 01-05-2010 03:58 AM
TIG welding Steel/Iron welding with Argon? Rich05 Welding, Brazing, Soldering, Sealing 9 12-01-2007 07:11 PM
Any source for an orbital action spindle??? rod chamfering? InspirationTool Mechanical Calculations/Engineering Design 3 06-04-2007 10:16 AM
Global Warming: The Orbital Solution dillyh Environmental & Alternate Energy 7 04-19-2007 06:41 AM
Best Method musky2much WoodWorking 1 10-13-2003 08:59 AM
