Go Back   CNCzone.com-The Largest Machinist Community on the net! > CAM Software > Mastercam
Mastercam Discuss Mastercam software here.
Old 02-02-2010, 09:28 AM
jolulank jolulank is offline
jolulank is on a distinguished road
Can't import EPS into Mastercam
Hello,
I have this problem. I am using inskcape to transform a logo and then I export the file to an EPS, when I try to open it in Mastercam 9 (router) it only shows part of it, sometimes nothing. So I can import, just not as expected.
I have attached the logo I am trying to import and the result I get.
I have tried a lot of things before saving my file in inkscape like changing fill and stroke, also combine, difference and all the options I get in the object menu in inkscape.
Anybody has any idea?
Old 02-02-2010, 10:05 AM
loud3803's Avatar
loud3803 loud3803 is offline
loud3803 is on a distinguished road
Have you tried to print it as a .PDF then use a PDF to DXF file conversion utility?
Or can Mastercam import .WMF files, if so, download Open Office from http://www.openoffice.org and import your graphic into draw and save as a .WMF.
Hope this helps.
Louis
Old 02-02-2010, 10:52 AM
I tried as a JPG but it was the same result. I will try it your way and see what happens.
JLL
Hope this helps.
Louis
Old 02-02-2010, 12:58 PM
Toonz Toonz is offline
Toonz is on a distinguished road
Can you save it as other file types (something other than .eps) that Mastercam can import? Go thru all the possibilities. Some work better than others.
Old 02-02-2010, 01:23 PM
I have tried that, but I get the same result. Now I think it might be a compatibility between Inkscape and mastercam because in some files MC imports parts of the file, not the whole thing. I think I will try Adobe Illustrator and see what happens.
JLL
Old 02-06-2010, 05:23 PM
Yupower Yupower is offline
Yupower is on a distinguished road
i use corel
then save it as dxf or drw
make changes in autocad-explode etc...
then import the dxf into mastercam and covert splines to arcs and make your geometry
Old 02-06-2010, 06:08 PM
syon syon is offline
syon is on a distinguished road
Sounds like you got locked out of the mastercam software.
Is it a legit copy?
i have seen this behavior many times, and its usually because they have gotten the copy from work or from someone that they knew that they knew that they knew....follow the drift.?
Old 02-08-2010, 03:03 PM
Thank you,
I will try that but using Illustrator instead of Corel
JLL
Originally Posted by Yupower View Post
i use corel
Can you import a... brianklein Mastercam 2 11-05-2009 04:52 PM
Need Help!- Import simple image in to Mastercam? VoKuS Mastercam 2 02-07-2009 05:21 PM
how to import to from solidworks to mastercam cob Mastercam 15 01-05-2009 06:58 AM
DXF Import Martin Long Syil Products 1 07-13-2008 10:38 PM
import DXF qmas99 FeatureCAM CAD/CAM 1 07-19-2006 07:08 AM
