Old 03-24-2005, 04:03 PM
miljnor's Avatar
miljnor miljnor is offline
S.N.A.F.U.
Cheap overpriced MILL build log
well here is my Mill! It will probably take decads to build but I will post pictures as I go. Sorry for the photo quality but my phone is the only camera I own. Gues I will have to go buy one just for this!
enjoy!
ID:	6533   Click image for larger version
ID:	6534   Click image for larger version
ID:	6535   Click image for larger version
thanks
Michael T.
Adapt, Improvise -- Overcome!
k.r.t.
Old 03-26-2005, 04:13 PM
miljnor's Avatar
S.N.A.F.U.
hear is a concept of the finished product.
thanks
Michael T.
k.r.t.
Old 03-26-2005, 04:15 PM
miljnor's Avatar
S.N.A.F.U.
last upload didn't take. here it is again
thanks
Michael T.
k.r.t.
Old 03-26-2005, 04:18 PM
miljnor's Avatar
S.N.A.F.U.
damn the file attachement aint working.. anyone want to tell me how to attach jpeg files?
thanks
Michael T.
k.r.t.
Old 03-26-2005, 04:23 PM
kong kong is offline
kong is on a distinguished road
Should work ok unless it is a big file?
Old 03-26-2005, 05:33 PM
balsaman's Avatar
balsaman balsaman is offline
Don't forget to click "upload" after browsing for the file.
Is that mill a scratch build or did you start with something?
I wish it wouldn't crash.
Old 03-26-2005, 07:06 PM
miljnor's Avatar
S.N.A.F.U.
I started with a very used Ruttland round column bench top mill. Motomitch's square column conversion inspired me to do the same. The one thing I'm doing alot different is using a Air cyclinder as a counter balance insted of a large weight.
I tried to upload the jpeg file (converted from solidworks) the same way I did the initial photos and it dosen't seem to work.
I am giving it another go so if there is a picture then.....
Name:	cnc mill assem.jpg‎
thanks
Michael T.
k.r.t.
Old 08-04-2005, 08:14 PM
miljnor's Avatar
S.N.A.F.U.
here is some more progress on the very expensive not enough time in the day hobby project! The first is a close up of the spindle assembly and the second shows the spindle assemble with a spindle motor mount.. which i should have bolted up by tomorow But I still haven't got the pullys (do to lack of brainpower in ordering).
ID:	9167   Click image for larger version
thanks
Michael T.
k.r.t.
Old 08-04-2005, 08:15 PM
miljnor's Avatar
S.N.A.F.U.
wow those realy shrunk quite abit I will post them again with a little biger picture!
thanks
Michael T.
k.r.t.
Old 08-04-2005, 08:52 PM
miljnor's Avatar
S.N.A.F.U.
here are the bigger pictures TIR was Much less than .0005 (Didn't have a .0001 gauge handy )
ID:	9169   Click image for larger version
thanks
Michael T.
k.r.t.
Old 08-04-2005, 10:18 PM
ViperTX ViperTX is offline
Is that the spindle assembly from the Ruttland mill??
Old 08-04-2005, 11:00 PM
miljnor's Avatar
S.N.A.F.U.
the actual spindle is from the ruttland. I have just removed all of the casting and the lame quill down feed and re-used the spindle and the housing for the spindle. I have replaced the bearings with high quality Nipponees bearings. and use Kluber highspeed grease (the best on the plant @115.00 tube, I got it free ).
With this bearing grease combo i got very smooth action and have no perceptible deflection and in the tenths runout. (didn't have a .0001 gauge handy but will recheck soon).
The onlything I have to still do to the spindle assem. is make a front grease seal as the original is either non existant or missing. I plan to run flood coolant so this is a must!
thanks
Michael T.
k.r.t.
Cheap DRO Design playinsteel General Electronics Discussion 3 07-21-2005 11:54 PM
Version 1 Mini Mill project log mannster Vertical Mill, Lathe Project Log 23 05-18-2005 10:56 PM
Want a BIG CNC Mill, Cheap? (not an ad) pfeist General Metal Working Machines 1 05-05-2004 03:09 AM
Cheap vertical mill CNCadmin General Metal Working Machines 0 01-21-2004 05:50 PM
Mill Expert Helps Build the Ford GT OneCNC OneCNC 1 11-06-2003 08:17 PM
