Old 03-22-2005, 04:19 PM
kevincnc kevincnc is offline
kevincnc is on a distinguished road
Mach2 vs. DeskCNC
Has anyone used both programs? If so what are the advantages/disadvantages of each? Will Mach3 have a higher pulserate than 45kHz? Thanks if anyone can help with my decision-
Kevin
Old 03-22-2005, 04:27 PM
CNCadmin's Avatar
CNCadmin CNCadmin is offline
Site Owner
DeskCNC-
  • Has a CAM built in for making tool paths, very easy to use
  • Needs a external board to run machine
  • Pretty easy to create G-code and you can edit on the fly
  • NC side is not customizable as far as buttons, and has a few annoying quirks
  • handles excelon files, does a great job of creating files for engraving PCB boards
  • Can't program key short-cuts
Mach-
  • Needs no extra board
  • Totally customizable
  • Runs in a window environment
  • Pendant and joystick ready
  • Customizable screen and buttons
  • Can adjust feed rate on the fly
This is just a few of my findings
Site Owner-Webmaster-
Administrator
www.rfqwork.com
Old 03-23-2005, 12:01 PM
Thanks Paul, I think I'll try Mach2 unless someone else convinces me otherwise.
The PMDX breakout board looks good to me. Would you suggest any other breakout board instead?
Kevin
Old 03-23-2005, 12:16 PM
CNCadmin's Avatar
Site Owner
http://cnc4pc.com looks ready good, I have one coming in so will see.
Administrator
www.rfqwork.com
Old 03-23-2005, 01:02 PM
ger21 ger21 is offline
If you can wait a few months, Gecko will be releasing their G200X. Which should eliminate the need for a breakout board, and generate step pulses at 400,000 steps per second for 6 axis, as well as having many more inputs and outputs available. A special version of Mach2 will support it (Mach4?).
Or just try Mach2 right now. Limited to 45Khz. Mo higher pulse rate for the parallel port.
Old 03-23-2005, 04:37 PM
JFettig JFettig is offline
I have a cnc4pc breakout board and 2 spindle encoders, the breakoutboard is large, but seems pretty good, It runs off 5v and only had 5v outputs for relays and such, I have an axxus technologies breakout board which is quite nice, has some 12v outputs for relays.
The spindle indexer(encoder) is pretty decent too, works great, have one on both my mill and lathe.
Jon
Old 03-23-2005, 05:41 PM
Thanks guys, the CNC4pc stuff is cheaper, I would also add the "charge pump" board (why don't they call it a watchdog timer?). PDMX has a relay though. I need to compare them more carefully.
DeskCNC TP-100 Probe released imserv Product Announcements & Manufacturer News 7 03-11-2005 09:10 AM
Mach2 remembering position after shutdown..how does it know Moondog Mach Software (ArtSoft software) 10 02-14-2005 09:56 AM
2nd generation DeskCNC controller now shipping imserv Product Announcements & Manufacturer News 13 10-01-2004 07:22 AM
G Code and Mach2 InventIt DIY-CNC Router Table Machines 8 03-13-2004 02:46 PM
mach2 versus EMC georgebarr Mach Software (ArtSoft software) 3 02-22-2004 12:32 PM
