Old 11-04-2009, 02:01 AM
landmark landmark is offline
landmark is on a distinguished road
Question Do I need a need a line filter with my spindle?
I am about to set up my first high speed spindle and VFD and I need advice on line filters.
1. do I absolutly need one or should I wait to see if I have a problem.
I have a 5hp colombo that will be driven with a 12hp VFD running on single phase. I have been looking at a line filter on ebay and wondering if it was a good deal and would work for my purposes. Item number: 380080621896
It's a 3 phase 250v unit rated at 150amps per phase, way over kill for my single phase 250v 35amp set up. But the price is only $50 for new surplus.
If I split one line into two and ran my single phase into my VFD via this will I have a problem?
Thanks I'm a noob when it comes to spindles
Old 11-04-2009, 03:28 AM
draughted's Avatar
draughted draughted is online now
draughted is on a distinguished road
thats a hugely powerful spindle you've got there. more than i could afford.
Old 11-04-2009, 09:58 AM
That type (RLC) is most often used on the input supply side of a VFD, If you want to use one at all, I usually go with the simple three phase choke or inductor only on the motor side.
Old 11-04-2009, 10:06 AM
Al
Can you tell me more about the 3 phase choke or indicator I'm not familiar with those. Do you know where I could get one and what specs it would need for a 5 hp 400 hz spindle?
thanks
Scott
Old 11-04-2009, 11:01 AM
Otherwise known as line reactors
http://www.hammondpowersolutions.com...ne_reactor.php
Most transformer manufacturers offer them.
Old 11-06-2009, 12:21 PM
analogman analogman is offline
analogman is on a distinguished road
So far no issues with my VFD, my drive cable has individual shielding which helps, although a line filter might not have much of an effect there.
Old 11-06-2009, 01:15 PM
mactec54 mactec54 is online now
mactec54 is on a distinguished road
As Anologman has just said if you use good shielded cable you don't need anything else
& only ground the shield on the input end you will have no problems
Do not split your single phase line power supply or you will no longer have a VFD drive
Mactec54
Old 11-06-2009, 02:02 PM
It's my unterstanding that as long as your vfd is rated for twice the hp of the motor you are driving then you are able to run it off single phase, 5hp spindle + 10-12 hp VFD, as the vfd converts the ac to dc then makes its own three phase and since it's oversized I wont overload the units inputs.
Old 11-06-2009, 02:13 PM
In some cases, others do not de-rate the VFD on 1 phase.
Also, if you run the wire in flex conduit etc, make sure you twist the conductors tightly together, this also reduces EMR.
The ground wire would not be twisted with them, however.
Old 11-06-2009, 03:15 PM
Landmark you said in your first post that you want to split 1 line into 2 you can not do this
You have to use (2) 120v lines to make 240v single phase for your input on your drive
Mactec54
Old 11-07-2009, 11:17 AM
I took this to mean he intended running one side of the 240v 1 ph through two inputs as and the unit is being 3 phase, he was concerned about full populating the terminals?
Old 11-09-2009, 08:02 PM
skypoke skypoke is offline
skypoke is on a distinguished road
I'm running a 5KW Colombo, smaller VFD, 50' run though e-chain along with shielded wires for steppers, limits etc. Spindle is wired with Home Depot's finest extension cord mtl. No shielding, no reactors, no problems. Ever. 6' X 20' cap Mechmate.
Chuck
Need Help!- *NEWBIE* Power Line filter (Transformer vs. Filter) cjchands General Electronics Discussion 5 09-25-2009 09:36 PM
input filter emi/rf EvanVH Phase Converters and VFD 4 03-16-2009 06:42 PM
Dm2400 Line By Line Execution???? andrewtub Benchtop Machines 4 03-15-2009 02:48 PM
HELP WITH ERROR 9, SPINDLE LINE FAULT GROWLY Fadal 3 01-31-2009 02:09 PM
Line Smoothing, point /line no identification dz1 Visual Basic 8 12-15-2007 06:03 AM
