Old 02-08-2005, 11:13 AM
traveler traveler is offline
Smile El cheap air drier
Recognizing that many people build CNC plasma tables as a hobby and therefore need to keep the cost down I thought I would share an air drier design that has served me well. I used a piece of 4" tube about 36" long. Any size that you have would work but I think bigger is better in this case. I cut 2 disks 2" larger than the tube and drilled bolt holes around the outer edges to fasten them together. A circle the OD of the tube was cut from the center of one of the disks. The circle was welded to one end of the tube to cap one end and the remaining ring was welded to the other end to make a flange. The other disk bolts to the flange to cap that end. Weld in 1/4" coupling an inch from each end of the tube and a mounting bracket and it's done.
That's all basic stuff but the savings come with using a good quality floor dry in place of hard to find and expensive diseccant. get a pair of large panty hose ( I personally prefer new ones but that's your choice) and stuff one leg inside the other put them in the tube and fill with good floor dry. Connect your air hoses and enjoy dry air to your plasma. I happened to have a stainless tube but you could use carbon steel but may want to give it an epoxy paint finish to keep the accumulated moisture from rusting the inside.
Traveler
Old 02-19-2005, 03:13 PM
kanankeban kanankeban is offline
kanankeban is on a distinguished road
Could you post some diagrams of your design?
Regards,
Hector
Old 02-19-2005, 09:21 PM
Maybe this will clear the confusen up
this is the first time I have tried to insert an attachment. Hope it works
never set a pace you can't maintain
Traveler
Vacuum Hold down for wood. HomeCNC DIY-CNC Router Table Machines 46 07-24-2007 12:16 AM
Shop air advice needed Swede General Metal Working Machines 25 10-17-2006 09:22 PM
Cheap DRO Design playinsteel General Electronics Discussion 3 07-21-2005 11:54 PM
How Cheap is Cheap??? HomeCNC DIY-CNC Router Table Machines 37 08-03-2004 12:01 AM
Air Bearing Spindle KBW DIY-CNC Router Table Machines 0 11-11-2003 09:44 AM
