Old 02-02-2005, 01:49 PM
fiedd fiedd is offline
fiedd is on a distinguished road
Autocad fonts (letters) to .dxf files
I'm new to this, but I am trying to vinyl cut letters on my Sherline mill with Mach2. I can do it from the write wizard, but can't get letters, fonts to convert from autocad, I have no problems with clipart. When I load the g-code, there is just a couple of lines of code, but no words or letters, mayby this can't be done.........
Old 02-02-2005, 01:56 PM
ger21 ger21 is online now
If you have the express tools, you can explode the fonts into polylines. This might even be included in newer versions. (I'm using 2002)
Old 02-02-2005, 04:30 PM
Thanks, I have explode, but it doesn't do anything with the fonts in autocad, mayby I should try importing or paste another font in. Do you know if there are some font programs that work well with g-code that aren't very expensive...........Don
Old 02-02-2005, 05:32 PM
Bubba's Avatar
Bubba Bubba is offline
Bubba is on a distinguished road
Don,
This is NOT the normal Explode, but it is in the EXPRESS tools and is explicitly for exploding text that has been selected.
Normal Explode will NOT work on text.
PM me if you want more help and let me know specifics etc.
Country Bubba
(Older Than Dirt)
Old 02-02-2005, 10:15 PM
ChrisJ ChrisJ is offline
ChrisJ is on a distinguished road
A utility can be downloaded from here:
https://www.qwerks.com/order/buynow.asp?ProductID=3121
"outlineart". It will convert truetype to dxf files.
It has a trial download and cost $20 if you want to own it.
Works O.K. Watch out as you increase the precision though, will generate many segments on the arcs, since the program doesn't creat curves into arcs but into small line segments.
I hear some others using Adobe Streamline. This will cost you $100+. I believe this program will convert curves into arcs not line segments, but not 100% sure.
Old 02-03-2005, 09:43 AM
Thanks, I have autocad lite 2004, but I don't see express tools. Will look into Adobe Streamline, are there any others out there that work well for less than $100, thanks.........Don
Old 02-03-2005, 10:00 AM
Is there a font program out there that just writes to g-code or .dxf files, thanks.........Don
Old 02-03-2005, 10:01 AM
ToyMaker's Avatar
ToyMaker ToyMaker is offline
ToyMaker is on a distinguished road
CorelDraw will export to .dxf . Older versions are available on auction sites for $15 and up.
I have not tried fonts exported this way. If you try this please let us know how it works.
robotic regards,
Tom
“The State exists for the sake of society, not society for the sake of the State.”
- - Woodrow Wilson, 28th U. S. President
Old 02-03-2005, 10:18 AM
Bubba's Avatar
Don,
Look on your CD, it is a seperate "setup.exe". I don't have my CDs in front of me and I don't remember "exactly" where it was.
You should have the necessary information to be able to install it, but please note that as long as autodesk has had the utility, it still has bugs. Text explode will mangel the first character of a string and when exploded, may not appear in the same position as originally placed. My work around is to add a "dummy" character to the front of the string to be exploded and when exploded, move the result to the location I want.
If you have a busy drawing, it is best to locate the source string outside the drawing area and then move it to proper position after it is exploded.
Country Bubba
(Older Than Dirt)
Old 02-03-2005, 10:28 AM
Like Chris said, get OutlineArt. Try this link instead. http://www.freefirestudio.com/outline.htm
This will give you the exact same thing as the Express Tool explode text, only it's better. You won't have to clean up the text afterward. Just export from OutlineArt, and open the .dxf in ACAD.
Old 02-03-2005, 10:45 AM
Not sure, but I think Coral draw is like Autocad Lite in that will not convert fonts, does anyone know for sure, thanks..........Don
Old 02-03-2005, 12:19 PM
buscht's Avatar
buscht buscht is offline
This is free, you can't beat that price.
http://www.deskam.com/deskengrave.html
Gcodein - lisp program to read cnc files into autocad wjbzone Autodesk Software (Autocad, Inventor etc) 32 05-10-2006 09:08 AM
AutoCad 2000 Missing .dll file E-Stop Autodesk Software (Autocad, Inventor etc) 12 05-30-2003 12:43 PM
