Old 01-23-2005, 07:14 AM
sidecar82 sidecar82 is offline
sidecar82 is on a distinguished road
my new sidecar
just got this home 600 bucks came with drill chuck no key
but its painted NASA oange really pokes you in the eye
pealing in spots to
just collecting cnc servo drive equipment
bought 4 of them 50 VDC 2100 RPM SERVO MOTOR
2 have 5/8 shafts?
2 have 1/2 shafts?
trouble all ready
got to get
The E4 series from USDigital. 250 Cpr encoder
power supply
geco 320 drive
got seperately
Rotary table and a 6 inch vice 2" boring head
set of Morris taper #3 collets 3/8 draw bar hole though
machinje came with a 7/16?
will have to post pictures
just collecting now its cold out in the garage
Name:	bench mill.jpg‎
ID:	4835   Click image for larger version
Name:	DC Servo motor.jpg‎
File Type: txt bench mill.txt‎ (249 Bytes, 136 views)
Old 01-23-2005, 07:17 AM
SPECIFICATIONS
Power: 1.5 HP
Swing: 15 7/8"
Maximum spindle travel: 5"
Column Diameter: 4 1/2"
12 Drill speeds
Speed Range: 120 ~ 2580 RPM
Spindle taper: MT3
120V - 60 Hz
Chuck size: 1/8" ~ 5/8"
Shipping Weight: 700 lbs
Old 01-23-2005, 08:18 PM
power supply ?
one for each axis
http://www.powersupplydepot.com/15081-PS.htm 4.2 amp 48 volts
or
http://www.powersupplydepot.com/12425-PS.htm 3.2 amps 48 volts
or
will this run them all
http://www.powersupplydepot.com/6646-PS.htm 10 amps 48 volts
150 bucks ?
what about 5 volts
its great to know what not to do
as we can play a game of Chest with the stepper motors that we have
all different sizes colors different Wires got a bunch of stuff all ready
I been getting liner guides from work that have been thrown away
for what ever reason
Old 01-26-2005, 07:17 AM
this is it
this is a picture of the mill I got
I picked it up in fort worth Ind and took it to lansing in a
ranger 230 miles
the repair shop called and said that my back axel is fixed
and come on in and lets talk about it I got good news and Bad
I just had them put new brakes on [:{ but the truck has 125,00
on it and I was dooing donuts earler
only look with one eye
stand is 3 X 3 1/8 thick wall welded 1030 mild steel
Name:	nasa mill.jpg‎
ID:	4901   Click image for larger version
Name:	nasa mill on revers switch.jpg‎
ID:	4903   Click image for larger version
Name:	nasa mill no revers switch.jpg‎
ID:	4904   Click image for larger version
Name:	nasa mill left.jpg‎
Old 01-26-2005, 07:59 AM
balsaman's Avatar
balsaman balsaman is offline
Sweet. You bought it used or new?
ranger 230 miles
I wish it wouldn't crash.
Old 01-29-2005, 02:55 AM
mill new
bought it to
Homier Distributing
325 Hauenstein Road
Huntington, IN 46750
Phone260)356-0816
Hours: M-F: 8am - 7:30pm
Sat: 8am - 6:30pm
Sun: 11am - 4pm
I called and asked if they had one in stock and they said yes
shipping was going to be 168 dollars and it wasent to my door step
they said they have a hilo and can put in the back of my ranger
http://www.homier.com/default.asp?dp...tail&sku=03988
Old 01-29-2005, 03:04 AM
vice and rotary table
I got these at Kitts a local tool store
ID:	4945   Click image for larger version
ID:	4946   Click image for larger version
ID:	4947   Click image for larger version
Old 01-29-2005, 03:14 AM
6 inch vice sides are ground square so that vice can be placen on its side
8 inch rotary chinese imitation Kitts said that if the handel is cranked
and cranked so that the table is rotated 760 dregees or more
eventually it will jam? any body hear of that?
Old 01-29-2005, 03:21 AM
50 volt DC motors
ID:	4949   Click image for larger version
ID:	4950   Click image for larger version
ID:	4951   Click image for larger version
Old 01-29-2005, 10:27 PM
how about 3 of these for power supply
they are $4.95 24 volts 2 amps
http://www.goldmine-elec-products.co...item=3&mitem=4
Old 01-29-2005, 10:30 PM
another choice
http://www.mpja.com/productview.asp?product=12418+PS
$39.95 24 volt 4.5 amp
Old 01-29-2005, 10:32 PM
JFettig JFettig is offline
I dont think you would be able to power one of those motors with 3 of them.
Take a look at the 10a 24v transformer or 2, maybe more from mpja
Jon
Mill/Drill conversion coming right up! balsaman Vertical Mill, Lathe Project Log 214 04-29-2009 09:04 PM
Square Column Mill/Drill Conversion Jay Kyle Vertical Mill, Lathe Project Log 14 08-23-2005 02:42 PM
Harbor Freight Mill/Drill Conversion Log Halfnutz Vertical Mill, Lathe Project Log 31 04-13-2005 11:56 PM
Converting a Mill/Drill to CNC NeoMoses General Metal Working Machines 3 02-04-2004 04:29 AM
