Old 01-29-2005, 09:11 PM
owhite owhite is offline
CNC laser table -- support for part
I have a table I'm building that is going to cut sheet metal. It doesnt work yet, but it will use a 100 watt CO2 laser. (Please resist the temptation to post that 100 watters dont cut sheet metal -- they do).
My question is about the platform/support that will hold the sheet metal.
The original top on my CNC table was a 1/2 thick plate of aluminum. I bolted down 24 disc shaped neodymium magnets on this plate with a 4-40 socket head bolts. The idea behind these things is that they'll supply some magnetic force on the sheet metal to hold the sheet in place. The main thing I like about the system is that it is very level. This is important because the "sweet spot" of the beam waist is rather small, and changes in the Z-height of the metal will could result in cases where the beam will not pierce the metal.
The set up as it is now works fine in that they hold the sheet metal quite nicely. The bolt head projects about 1/8th of an inch above the magnet but because its made of steel it transmits enough magnetic force up the post to adhere the sheet metal.
The question I got is if this system will work. One thing I'm wondering is if the beam hitting the aluminum plate will put off undersireable fumes. The other question I have is if there should be more distance between the part and the support underneath. The gap between the sheet metal and the aluminum is around 3/8ths of an inch. I think it'd also be better if I had a grate underneath the part. That would definitely make for better ventilation -- I could put a vacuum system below the part to pull off fumes. Comments are welcome.
This is the table:
http://nilno.com/laser_dir/mag_table_003.jpg
These are examples of the magnets:
http://nilno.com/laser_dir/mag_table_004.jpg
This is a part held on the table.
http://nilno.com/laser_dir/mag_table_005.jpg
owen
Last edited by owhite; 01-29-2005 at 09:14 PM. Reason: I think the title was too generic.
Old 01-29-2005, 11:52 PM
stevelang stevelang is offline
stevelang is on a distinguished road
I can't help you on this but would appreciate if you can provide some info on the laser cutting part of your project
Old 01-30-2005, 04:46 AM
Romos V. Romos V. is offline
Romos V. is on a distinguished road
Owen,
<<(Please resist the temptation to post that 100 watters dont cut sheet metal -- they do). >>
Actually, they don't....
There are 4 kinds of Co2 laser.
1) Continous wave (100w laser of this kind, delivers 100w maximum)
2) Gated pulse (100w laser of this kind, delivers 100w maximum)
3) Superpulse (100w laser of this kind, delivers 100w X 2.5 times)
4) Hyperpulse (100w laser of this kind, delivers 100w X 2.5 times)
G-100 is a Superpulse laser and it has 250w Peak effective power.
Now, about your table... It will be better if gap between the sheet metal and the aluminum is more than 3/8ths of an inch. If this gap is small, the reflected heat will bend the stainless steel sheet.
Now, about your calculations...
(At 1.6mm, if I have a 3x beam expander I get 4.8 mm, which will be 103
micron using a 1.5 inch focal length)
(equation: diameter = .013 * M^2 * (fl/D) where M^2 is equal to 1, and
D is diameter of incoming beam.)
Where did you found 1.6mm?
Here is a table for G-100.
Distance From Laser (mm) vs Beam Diameter (mm)
0 mm distance = 1.9 mm beam diameter
250 mm distance = 2.9 mm beam diameter
500 mm distance = 4.7 mm beam diameter
750 mm distance = 6.7 mm beam diameter
1000 mm distance = 8.7 mm beam diameter
1500 mm distance = 12.9 mm beam diameter
2000 mm distance = 17.2 mm beam diameter
In my case, the focal lens from the laser dinstace is 500 mm.
So, without any beam expander I have...(assume that M^2 = 1.5)
diameter = .013 * 1.5 * (38.1/4.7) = 0.158mm
Romos
Old 01-30-2005, 10:02 AM
Originally Posted by Romos V.
Owen,
Now, about your table... It will be better if gap between the sheet metal and the aluminum is more than 3/8ths of an inch. If this gap is small, the reflected heat will bend the stainless steel sheet....
Romos,
excellent information, as always. Regarding the reflected heat -- I could put the magnets up higher on 2.5 cm posts, and still use the aluminum plate below.
Do you think that a larger air gap above the plate will be okay or will it still reflect heat and bend the metal?
I remember that you use rows of angle iron that looked like LLLLLL. I can create something like that. I'm trying to decide if using the plate as a support is okay, or if I should make something that will be more complicated.
Owen
Old 01-30-2005, 11:10 AM
Owen,
it will still reflect heat but bigger gap will be better. Not only for the heat. When gap is small, small pieces from the melted metal will hit the aluminium plate, and they will go on the back of the metal sheet.
Romos
Old 01-30-2005, 11:57 AM
Romos,
thank you for your comments on my calculations. The distance to my beam expander is 33cm, so using your chart the beam size will be about 3.5mm when it goes into the expander. The beam expander is 3 times the original size so the beam will go to 10.5mm.
Based on the equation:
diameter = .013 * 1.5 * (38.1/10.5) = 0.071mm
This is a great spot size. The problem will be my depth of field. This is based on the formulas shown on this site:
http://www.parallax-tech.com/faq.htm
Depth of field is the distance range that an object can be placed in front of the lens and still get cut. The forumula for depth of field is
DOF = 2.5 x wavelength x ( focal_length / beam_diameter )^2
for our laser it calculates to:
DOF = 0.027 * (focal_length / beam_diameter)^2
I made a chart that gives examples of our two situations.
The first row is what happens with your laser. You have a focal length of 38 mm, beam diameter of 4.7, you get 158 micron spot size, and 1.8 mm depth of field. My current situation I have a 10.5 beam diamter, a 71 micron spot, and a small small depth of field of less than a milimeter.
I tried to other variations. One would be if I had no beam expansion. My beam diameter would be around 3.5 (close to yours) and a slightly larger spot size. This might work, but it also may not be enough power density to cut metal.
The last row of the chart is where I use a focal length of 4 inches with the beam expander. If I do that, I get a spot size of 190 micron, and 2.5mm depth of field.
I know that since I may be cutting other materials I will want to have more than one focusing lens anyway, so maybe its time to look into purchasing them.
owen
Old 01-30-2005, 12:05 PM
Owen,
Romos
Okay based on your comment I think I'll raise the height of the magnets for now and run a fan to blow air away from the cutting. I want to get something set up just so I can do some testing before making the most perfect and complete solution. One of the things that's frustrating is that I will be able to make a honeycomb support -- once I can cut sheet metal. So I want to get it working so it can start bulding parts to complete the project.
owen
Old 01-30-2005, 03:00 PM
sendkeys sendkeys is offline
hiya owhite
i recognize your servo's
If you dont mind me asking some questions
How do they run?, power?, heat? what voltage did you go with?
What controller did you use? , working good??
Looks like you're running the sevos 1.1 ratio. how is that working out?
THanks
Old 01-31-2005, 06:24 PM
Originally Posted by sendkeys
hiya owhite
THanks
Here are some specs on the motors:
http://nilno.com/laser_dir/2003_12_0...28957759165454
here are some calculations for its power supply:
http://nilno.com/laser_dir/2003_12_0...48459727349689
This is a thread on cnczone that was about changes I made to the toroid:
http://www.cnczone.com/forums/showthread.php?t=2924
The motor drivers are gecko G320s, the motor controller board is called a Universal Stepper Controller, found at:
http://pico-systems.com/univstep.html
I like the UCS, the geckos, and the motors just fine. I'm told by Mariss, grandfather of gecko motor drivers, that they are oversized for my application. The problem with oversized motors if somehow the encoder were to fail, and the motor just ran at full speed, you damage everything. Now since nothing ever breaks in CNC work, the encoders couldnt possibly fail on me >>insert big eye-roll here<<
owen
Old 01-31-2005, 10:23 PM
Thanks for the links and info
Old 02-06-2005, 07:17 PM
So I made a new rack for the top of the CNC table. Its made of 3/4 inch aluminum bar stock. Its held together with threaded rod. Aluminum tubes were cut 1 3/4 inch for spacers.
There are neodymium ring magnets attached with small bolts in on each bar. The neodymium rings came from ebay. If you search on neodymium you'll get a million hits. Nice stuff, but you cant machine it, so I purchased the ring variety for easy bolting.
owen
ID:	5096   Click image for larger version
Old 02-17-2005, 11:33 AM
Owen,
I made some testing for you, and I took some pictures.
Case 1 (I don't have beam expander)
lens distance from laser: 500mm
focal length: 1.5"
Material: Stainless steel 2mm
Samples are 2 and 3cm height.
There is no buildup of material on the back of the cut
ID:	5305   Click image for larger version
ID:	5306   Click image for larger version
ID:	5307   Click image for larger version
Build a CNC rotary table? (longish) jcolley Mechanical Calculations/Engineering Design 0 02-12-2005 09:23 AM
Rapid prototype CNC laser resin. (Stereolithography) ynneb CNCzone Club House 3 04-25-2004 09:17 AM
Cost / Price of a DIY CNC table. Havic DIY-CNC Router Table Machines 10 03-01-2004 03:08 PM
