Old 01-09-2005, 08:24 PM
Stevie Stevie is offline
New CNC drill I'm building; just about finished
Overall view of the machine; as you can see it's not quite finished; i have some wires to tidy up and I still need to move the drives under the bench etc; the drill is brand new and was just $69.99 from Home Dept
All the drives I had along with the step motors
It will become a 4 axis very soon; the normal table will be removed and more linear rails will be added below the X axis; this will allow me to cut across the job for flats etc
Close up of the Z axis drive motor and timing belt setup; I removed the return spring for the timing gear wheel; i still need to add a spring to keep the spindle against the gear to stop backlash
Close up of the C axis; this axis will rotate to the exact angle specified by the computer (note; that rotary head was the old head from the lathe before the big update)
General view from the other side; note the use of muffler clamps to hold the stepper drive motor support; the motor is fastened to the Alum angle on a Lexan plate; the drives that control the step motors can be seen behind the unit; the small linear slide in front of the rotary axis will become the tail stock to hold long jobs while they are drilled
What did you build today?
Old 01-09-2005, 09:21 PM
Talking
But will it work
Yes it works
3 rows of holes center drilled 0.5mm deep; 5mm row to row; 30dgr apart
Old 01-09-2005, 09:28 PM
JFettig JFettig is offline
Very nice, looks good. How rigid is a head like that for the A(or C) axis? Would it be suitable for milling? It wouldnt be all that difficult to get a mini lathe spindle and use that for a 4th axis.
Jon
Old 01-09-2005, 09:40 PM
balsaman's Avatar
balsaman balsaman is offline
What did you build it to do?
I wish it wouldn't crash.
Old 01-09-2005, 09:50 PM
It will drill my barrels; some have flash holes in the muzzle; i need to drill them
Here is one I'm working on the prototype of the 262 barrel; remember this is the prototype; it's not the finished artical and is not up to scratch as far as my normal standards
This is the biggest cannon ever fitted to the aircraft; just one in the nose; they built 3 of them before the wars end
I'm making these for another Canadian; he's in Austria; and once I get the drilling done by CNC he will cast the resin breech onto the barrel
Scale is 1/32nd
The muzzle is drilled to leave only 1/2mm wall; then a muzzle cap is pressed onto the thin shell
This shell is then drilled with many small holes; the barrel is drilled scale 50mm up inside the thin shell (about 7.5mm in)
This is one long cannon barrel almost 100mm
Another muzzle view
and finally no gun is of any use without rounds
After this I'll be looking to prototype a 30 mm GAU-8/A seven-barrel Gatling gun
Old 01-09-2005, 09:53 PM
Jon
That C axis is a lathe spindle; and yes it is very ridgid; the drill spindle should be good enough it's brand new; plus i open 4 boxes to chk the spindles untill i found one really tight
I'll be adding a Y axis over the next few days; the drill table will be gone then; and the 2 linear slide mounted right on the machine base; another stepper will control the Y
Old 01-09-2005, 09:58 PM
Those are very cool,
What I was wondering is would it hold a part while being machined, the stepper and all?
I am considering getting a rotary table, but I do not like the ones available and a spindle from a mini lathe is only about $30 and a chuck is around $40 and I can make/have the rest.
Jon
Old 01-09-2005, 10:01 PM
It's a 3-1 reduction with 300 oz/in hold; i think small cuts in brass with a 1/16th or 1/32nd cutter will be no problem at all
Old 01-09-2005, 10:35 PM
Ken_Shea Ken_Shea is offline
As always Stevie, Impressed/envious, thanks for taking the time to share your work with the CncZone.
Ken
Old 01-09-2005, 11:22 PM
fyffe555 fyffe555 is offline
fyffe555 is on a distinguished road
Stevie,
excellent work again.. I'd like to see the finished model.. is this a flyng model?
The 'biggest cannon ever fitted to the aircraft' might be off though.. The 262 tank buster had a 50mm cannon? The DeHavilland Tsetse (Mosquito varient) had a 57mm ( six pounder molins) rapid fire cannon for killing U boats and shipping with. Weighed over 3500lbs, 18ft long and filled the entire bomb bay. Fired in a dive it would knock 100mph off the speed of the plane. The 130 gunships use a 105m cannon too..
Old 01-09-2005, 11:25 PM
Originally Posted by fyffe555
Stevie,
I ment the ME262; i know other aiircraft had bigger
Old 01-10-2005, 06:14 PM
STAY TUNED; I'M GOING TO ADD A 2ND SPINDLE AS WELL AS THE FORTH AXIS
Humm caps lock
Building CNC Surface grinder - whole lotta questions rashid11 General Metal Working Machines 6 03-09-2006 03:53 PM
Heads Up - Article about building CNC Milling Machine samualt CNCzone Club House 3 06-13-2005 03:43 PM
CNC Drill driving the milling table Com Vertical Mill, Lathe Project Log 2 04-04-2005 04:27 PM
Should I consider building a cnc or just buy one? johnt CNC Plasma and Waterjet Machines 18 03-28-2005 12:19 PM
My first CNC router: 1.5 years building hddjohns DIY-CNC Router Table Machines 2 04-03-2004 11:18 AM
