Old 03-26-2009, 04:13 AM
Guldberg Guldberg is offline
Guldberg is on a distinguished road
My KX3, tweaks and various stuff
Hurray. Yesterday it arrived in a giant crater. My very own brand new Sieg KX3.
This is going to be my log for the various tweaks and mods i plan to do.
Here is the stuff i plan to do:
A solid stand and full enclouse
Bolt the coloum to the wall to increase rigidty
ATC, Hass style
Well, now for the pics (there are plenty more if you follow the link to the picasa album)
The mandatory crate pictures. I got it delivered at my home. Since i live in appartment it had to spend the night outside.
From KX3
Today the carrier picked it up and transportet it to the student workshop where i do my hobby. Off the crater went, and look what i found inside
From KX3
The pallet was 1m and the door 0.9m, so i had to fine tune it with a jig saw. Anyway, this is how it looks right out the box
From KX3
The first thing i did was to remove that strange splash protective thingy around the table. Hereafter I noticed that the limitswitches was set a little to the safe side, thereby loosing some travel, so i adjusted them properly. Also i removed that hideous red grease. At least it was only a thin layer in most parts.
Of cause I had to open it up and have a look inside. Neetly wired. Look at that huge power supply
From KX3
A look into the back, where all the spindle hardware is hidden
From KX3
I also took off the top cover, you can get a glims of the spindle motor
From KX3
First program running. Just a simple circle test to hear it humming.
And lastly the goodies i bought along with the mill. The wooden box is a complete set of parallels.
From KX3
Thats it for now. Maybe ill do a small test cut tomorrow, but before it sits bolted to a solid stand its hard to make a judgement
Old 03-26-2009, 09:20 PM
dfmiller dfmiller is offline
dfmiller is on a distinguished road
Got mine direct from Factory. I am in Canada. Serial number is 0234.
I have not done too much with it yet. Make sure you get the updated Seig Logo file from the support site. Also I suggest getting the updated driver files from the support site also. I found the disk shipped had issues with what they shipped. Also I found don't try to upgrade to the lastest Mach 3. use what is on th esupport website.
My experience is by doing this you will save yourself several days of hair pulling.
I am really happy with the machine and need to find time to use it more soon
Dave
Old 03-27-2009, 12:35 PM
It says 3/08/0157 on the front, not sure if that is the seriel number
As for the xml file it worked right out the box,. Cant remember what version of mach im using.
Old 03-29-2009, 11:17 AM
I believe the 0157 is the serial number. I am glad you have no software issues.
Old 04-22-2009, 04:47 PM
Its not that i havent been busy in the workshop, my girlfriend just went away to Italy for 3 weeks with my camera. So not so many wip pictures. I almost finished the frame structure for the enclosure.
From KX3
From KX3
When i was welding, some sparks hit my hand and i accidental drop the torch, which swung around and apprently pierced my leg. I kinda noticed my green pants got dark. A thin layer of fabric is no match for a red hot wire.
A very odd injury, my pants got soaked in blood in less than 10sec and then it all stopped. Hurray for coagulation...
From KX3
From KX3
Old 04-26-2009, 02:18 PM
Now in stylish white
From KX3
And with door sliders installed
From KX3
Closed
From KX3
And tadaaaa open
From KX3
Old 04-26-2009, 09:56 PM
zephyr9900's Avatar
zephyr9900 zephyr9900 is offline
zephyr9900 is on a distinguished road
Looking good, Jacob. Those slides look a lot like Accuride. If so, very high quality--I've used them in a commercial product. I'm glad that you have blood that coagulates quickly!
Randy
Old 04-28-2009, 06:37 AM
I think it is accuride, the quality seams nice and they are payable. Wheels on a rails like in the commercial cncs would have been better, but it seams to work for now
Old 04-30-2009, 02:35 PM
Got most of sides welded on
From KX3
From KX3
From KX3
From KX3
Old 04-30-2009, 03:09 PM
nlancaster nlancaster is offline
nlancaster is on a distinguished road
that is a great looking enclosure. how do you keep the swarf/coolant from going out the slot for the door?
Old 04-30-2009, 03:38 PM
There is something like 80cm from the spindle to the the slot, it would take some crazy blasting to make it spash all that way. I also welded on an angle to stiffen the side on the inside, which blocks the direct "line of sight" from the spindle to the slot. Anyway, what is a shop floor without a little coolant and some swarf..
From KX3
Old 05-08-2009, 12:45 PM
Finally finished the welding. First layer of paint applied
From KX3
Will make a drawer for tools etc., not the first job in line though
From KX3
Today i made the "big lift". It was kind a nerve wrecking since i just used a bolt i found in the sealing :-) First i made eye bolt out of some scrap to fit the KX3
From KX3
Wrench attach and ready to go
From KX3
Scary stuff! I removed the pallet and as i lifted it I put sheets of plywood and some square tubes underneat, so if it broke it would only fall a couple of centimeters... at least that was the plan, glad never got to see if it had work.
From KX3
Finally it was sitting were its suppose to
From KX3
Ups, a minor clearence issue, will have to redo the power drawbar mechanisme to make use of the full travel
From KX3
Eager to test it, i went and milled out the two bars for the power drawbar
From KX3
More pics in the picasa album as usual
My KX3, tweaks and misc. stuff Guldberg Benchtop Machines 3 03-26-2009 10:20 AM
new at this cnc stuff JAKE BISHOP CNCzone Club House 0 05-08-2008 11:47 AM
Coolant System Tweaks and Tricks Donkey Hotey Haas Mills 14 01-15-2008 11:02 AM
Mach3 tuning (cuts small stuff fine, but is off on big stuff) jdbaker Mach Software (ArtSoft software) 4 03-15-2007 11:30 AM
welding thick stuff to thin stuff - need advice cross6 Welding, Brazing, Soldering, Sealing 5 01-13-2005 01:39 AM
