Old 01-03-2005, 04:24 AM
lesd lesd is offline
lesd is on a distinguished road
tilt plasma cutter on each start to add tip life?
I am 1/2 way done building a plasma table/ wood router, and was thinking about how I may increase tip life. When I hand hold my Hypertherm torch, I often tip the head a little when I start the arc, so that the puddle that is formed before it blasts a hole is less likely to splash back up into the tip to cause wear. Am I kidding myself that it actually helps? If it should help, should I consider adding a 4th axis to my table to do the same thing while automated ?
Thoughts?
Thanks!
-Les
Old 01-08-2005, 04:39 AM
OK, so nobody has feedback on tilting the torch to extend tip life.
How about this:
About how many hole starts in 1/4" steel can I do with a Hypertherm 380's tip? 200 ? 2000 ?
Some of the patterns I want to cut have hundreds of hole starts, is the reason I'm asking all these tip life questions.
Thanks!
-Les
Old 01-08-2005, 08:33 AM
marx911 marx911 is offline
marx911 is on a distinguished road
one thing we do at work is punch starter holes before cutting ...since you are going to have a router head also you might be able to drill starter holes so you dont have to pierce...it would give you a place to lead in and lead out..
just a thought
Mark
Old 01-08-2005, 12:54 PM
Aksess's Avatar
Aksess Aksess is offline
Aksess is on a distinguished road
The best thing you can do to increase tip life is install a good quality air dryer. Moister will kill a tip quicker than any pierce point.
Old 01-10-2005, 10:48 AM
traveler traveler is offline
In my humble opinion Aksess had the most valuable input to this question. Hi quality (dry) air is essential to consumable life. It is intresting to think of angle piericing metal but it seems to me that the pierice point would require that the tip stay perfectly in place while the torch traveled to vertical position and the arc distance maintained. Perhaps it could be done but it looks like a programing nightmare to me, especialy in one off situations like I often encounter. Pre-drilling a pilot hole would certainly solve the problem but would the extra time involved be cost effective? Everyone would have to determine that for themselves.-------------DRY AIR---DRY AIR---DRY AIR---
Never set a pace that you can't maintain
Traveler
Traveler
Anyone tried Super-Tech Plasma Cutter Kit? muleworks CNC Plasma and Waterjet Machines 6 11-29-2005 12:10 AM
Adaptable to plasma cutter use? trent2530 DIY-CNC Router Table Machines 4 06-07-2005 07:19 AM
plasma cutter with deskam guy CNC Plasma and Waterjet Machines 0 02-14-2005 04:34 PM
Looking into Plasma or Laser cutter for sheet metal NeoMoses CNC Plasma and Waterjet Machines 11 01-06-2005 12:29 AM
Handheld Plasma Cutter with CNC? Jim Stein CNC Plasma and Waterjet Machines 5 08-28-2004 10:41 AM
