Old 12-21-2004, 09:12 PM
pyroracing85 pyroracing85 is offline
pyroracing85 is on a distinguished road
gear mfj
I am a beginner machinist. I am trying to make racing gears. I did some research and found out that a company makes them on a laser cutting machine. Would this be the most effective way of making a gear that is about 3/16 thick and with about 65 teeth on it made out of either aluminum or titanium
thanks for your help
Old 12-22-2004, 09:57 AM
I doubt that they would be good enough quality, but then, things change all the time.
Try Sterling Instrument for tiny gears.
Old 12-22-2004, 11:03 AM
roysol roysol is offline
roysol is on a distinguished road
machining gears
Water jet quality would not be appropriate for all but the crudest gears. I have used wire edm to make some very high quality gears. With either water jet or wire edm you may have to consider programming issues. Most production gears are made by shaving or hobbing on specialized dedicated machines. Another method is with the proper cutter form on a milling machine. this requires an indexer with the right spacing for the number of teeth, or a dividing head. Finally, I would point out that your material selections are extremely different. Aluminum is soft, wears easily, and is not very tempature resistant. Titanium is much tougher, more heat resistant, and more difficult to machine.
Old 01-01-2005, 10:58 AM
here is a picture and they use aluminum
Old 01-01-2005, 11:23 AM
Those look like chain sprockets, not gears
Yes, you could profile mill those without fancy gear cutting machinery, if you can develop the correct tooth profile.
Old 01-14-2005, 06:22 PM
How would I do that?
Old 01-14-2005, 08:16 PM
Ken_Shea Ken_Shea is offline
UH-OH
They do look like sprockets, are these chain driven ?
The first thing you will need is all sprocket dimensions so you know what you want to end up with, A cad program to draw this 2D profile and cam software to create the toolparh and convert to G-Code so that that your CNC mill will know what/where and how much to cut. In the midst of all this you have to know or learn how to do all of this.
Hope you are not in a hurry
Old 01-14-2005, 10:14 PM
thanks i'm learning g code now. then eventually after that mastercam
Old 01-14-2005, 11:36 PM
3t3d 3t3d is offline
3t3d is on a distinguished road
Take a look at this link:
http://www.gizmology.net/sprockets.htm
Pete
Old 01-14-2005, 11:43 PM
Here is a picture where the yellow represents the toolpath, along with the g-code for you to look at, you will see in this case the G-Code is a very straight forward XYZ moves.
Old 01-15-2005, 06:40 AM
thanks a lot i'm going to go play that at school
NASA gear bearing by mister Vranish wolphje General Metalwork Discussion 1 07-28-2005 02:28 PM
gear pitch 2muchstuff Mechanical Calculations/Engineering Design 5 04-02-2005 09:04 AM
Adding a manual gear change call MILLMANM Post Processors for MC 5 01-04-2005 11:05 PM
Basic Bevel Gear - Milling a valley for gear teeth ngr1 General CAM Discussion 9 04-17-2004 04:58 PM
