Old 12-18-2004, 11:30 PM
CNCadmin's Avatar
CNCadmin CNCadmin is offline
Site Owner
Shaft dia requirement, for a new laser machine design?
I need to know what the dia of a un-supported shaft needs to be for a span of 48" These shafts will be supporting my gantry for a laser cnc machine design. I really don't what to use a support shaft if I don't have to.
I'd like to use somthing like this-
Site Owner-Webmaster-
Administrator
www.rfqwork.com
Old 12-18-2004, 11:38 PM
CNCadmin's Avatar
Site Owner
I'm thinking 3/4" too 1" would work, mind you their is no up and down forces and no real weight on the gantry from the head.
Administrator
www.rfqwork.com
Old 12-19-2004, 12:20 AM
CNCadmin's Avatar
Site Owner
Here is my new laser-
Administrator
www.rfqwork.com
Old 12-19-2004, 10:39 AM
ViperTX ViperTX is offline
Yes, anything from 1/2inch up in diameter will work. You'll be using 2 of them.
Old 12-19-2004, 11:10 AM
ger21 ger21 is online now
Even 1" will sag a little at 4 ft, but it probably won't affect the cutting, I wouldn't think.
If you can double up the end mounting clamps, it gets quite a bit stiffer.
Old 12-19-2004, 12:00 PM
CNCadmin's Avatar
Site Owner
Where can I find this, I have looked un and down the internet
Administrator
www.rfqwork.com
Old 12-19-2004, 12:52 PM
Talking
Well darn...did some calculations...here they are for Thomson 60 shafts.
Unsupported Length = 48 inches
Weight of Load = 100 lbs
Deflection at the center of the unsupported length (24 inches) is:
1/2 inch dia. shaft ~= 2.493 inches
5/8 inch dia. shaft ~= 1.00 inches
3/4 inch dia. shaft ~= 0.49 inches
1 inch dia. shaft ~= 0.1536 inches
For a load of 10 lbs the deflection for the 1/2 inch shaft is 0.2493 inches. You can guess what the others are.
Paul
Old 12-19-2004, 12:55 PM
If you want to use the T-rail then you should buy shafting that is pre-drilled. Thompson has it....anyone that sells shafting has T-rail.....the one you picture looks like a home made one...but I'm not for certain.
Old 12-19-2004, 01:11 PM
fyffe555 fyffe555 is offline
fyffe555 is on a distinguished road
CNCAdmin
interesting project. Keep us up to date on how it goes.
How much load do these rails have to support?
The linear rails in post #6 are Igus Drylin S supported shaft part AWUM - metric only. They're hard anodized Aluminum for open plastic bearings only.
Pacific bearing do something similar too..
Old 12-19-2004, 04:13 PM
CNCadmin's Avatar
Site Owner
thank you this is what I was looking for- http://igus.bdol.com/drylins.asp
Administrator
www.rfqwork.com
Old 12-19-2004, 06:50 PM
trubleshtr trubleshtr is offline
trubleshtr is on a distinguished road
cool laser, is that the co2 set-up from amazing-1?
Old 12-19-2004, 06:53 PM
CNCadmin's Avatar
Site Owner
No, I got it from a ebay seller, It's a RF co2 laser.
Administrator
www.rfqwork.com
