Old 02-20-2009, 09:24 AM
mrchang mrchang is offline
mrchang is on a distinguished road
Mori SL-00 X axis Ball Screw
Am looking for an X axis ball screw for my Mori SL-00. Just took the noisy one out to find the previous owners brass machining dust had gotten into the X axis and pitted the ball screw.
Does anybody have a spare one lying around ?
Otherwise... I don't know who made it for Mori or the part number.... any help would be appreciated !
Old 03-02-2009, 10:13 AM
underthetire underthetire is offline
underthetire is on a distinguished road
sl00 ballscrew
If its not a Mori made ballscrew ( yes, they have a ballscrew mfg facility in the Nara plant) it would be most likely a NSK.
Old 03-02-2009, 11:02 AM
Mori Ball Screw
Thanks underthetire. It is a Mori discreet part most likely made in their own plant. I have spoken to NSK and they reckon it either isn't one of their parts or it's a 'locked' part meaning though they may make it you can only buy it from Mori, who want many thousands of dollars for it.
I also have a Victor TNS-3 which goes under the name Victor Fortune in the USA. I had a look at it's ball screw and it is the same 28mm OD, 6mm lead/pitch with the same taper end at the top servo end. Only difference is the Victor ball screw hangs in air at the other end whereas the SL00 is seated in bearings. I checked because the Victor machines of old are exact copies of the Mori machines.
So am still looking for a replacement ball screw......
Old 03-02-2009, 05:20 PM
ballscrew
Yes, Mori supports the screws on both ends. They usually stretch the ballscrews between the bearings for thermal expansion. If I remember correctly, the SL0 was not stretched, can't be sure though. You can have your ballscrew rebuilt though.
Z axis ball screw dgapilot Shopmaster/Shoptask 18 08-14-2009 06:20 PM
x-axis ball screw alignment. grinderdust Benchtop Machines 1 12-27-2006 06:44 PM
Z Axis Ball Screw Question rcazwillis General Metal Working Machines 7 11-15-2005 09:51 PM
Rotating Nut Ball Screw for dual X axis AeroKam DIY-CNC Router Table Machines 2 08-10-2005 12:05 AM
Z-Axis help - Ball screw too tight? samualt DIY-CNC Router Table Machines 1 08-27-2004 01:01 AM
