Go Back   CNCzone.com-The Largest Machinist Community on the net! > Mechanical Engineering > Linear and Rotary Motion
Linear and Rotary Motion Discuss ball/Acme screws, R&P, linear slides and theory here.
Old 01-25-2009, 11:54 AM
Zoidberg Zoidberg is offline
Zoidberg is on a distinguished road
Backlash free rotary table
I want to build a rotary table that can handle continuous milling!
Do you think my drawing would work?
The upper gear belt pulley can rotate freely on the axle, and is connected to the axle via the spring, and is preloaded.
Old 01-25-2009, 12:12 PM
RICHARD ZASTROW RICHARD ZASTROW is offline
RICHARD ZASTROW is on a distinguished road
As an alternative, "google" Howimat. This concept is ball driven like a ballscrew in the round.
Dick Z
DZASTR
Old 01-25-2009, 12:15 PM
I will check it out! I have also been thinking of using 2 servos and do the preload eletronically with a µC
Old 01-25-2009, 01:09 PM
BillTodd BillTodd is offline
BillTodd is on a distinguished road
Looks like it would work to me, although mixing gears, lubricant and timing belts might be a problem.
How about placing the two worm gears at an angle to each other, driving one directly and the other via a bevel gear? (if you see what I mean)
Or...
What about a buying or copying Commercial anti backlash worm drive ?
Bill
Old 01-25-2009, 01:16 PM
Hmm, thats an interesting idea! I'll make a drawing!
Old 01-25-2009, 02:30 PM
Faliure
I made a drawing and realized that the worms would need to rotate in the same direction in this configuration :P
The dual servo version seems more and more appealing!
Old 01-25-2009, 03:11 PM
Just swap the main-shaft bevel gear to the front of the perpendicular one.
Bill
Old 01-25-2009, 03:18 PM
BobWarfield's Avatar
There are a lot of commercially available low backlash drives on eBay. Search for "harmonic drive" or "bayside drive". One of those sure will least trouble and expense.
Another possibility is to preload the heck out of your rotab drive with another gear and some bellvues. Not sure how much torque you plan to put on it though.
People also run 2 of the main circular gears spring loaded to spread the teeth just enough to get rid of the backlash. In this case, you'd make the spread adjustable with a threaded screw.
These last two solutions seem prone to binding and wear.
I would be tempted to also consider a big timing belt drive. properly set up, you'll get minimal backlash. People are even using these for linear motion with good success.
For really high torque situations, you might still find a brake is useful. Slew the 4th axis to the desired position, send an M-code to lock the brake, cut, and unlock. Small disk brakes from everything from mini-bikes to lawn tractors are readily available and work with an air over hydraulic and solenoid valve.
Cheers,
BW
Old 01-25-2009, 03:19 PM
Aaah yes...
Old 01-25-2009, 03:24 PM
mc-motorsports's Avatar
mc-motorsports mc-motorsports is offline
mc-motorsports is on a distinguished road
Harmonic Drive is the way to go, if your willing to spend a little money.
http://www.powertransmission.com/iss...6/harmonic.htm
Old 01-25-2009, 03:30 PM
Or the seeking tooth variation:
Name:	Seeking Tooth gear1.gif‎
Bill
Old 01-25-2009, 03:38 PM
I want it to be able to use it for continuous milling, like gear hobbing and milling springs, not just indexing!
I think it's best to have the worms axially stiff because they can't be backdriven. So if you just can keep both worms in contact with the gear teeth with a little rotational preload it should be backlash free and much stiffer than the version with axial preload of the worms or split wormgear!
Harmonic drive seems nice! But i like to design and build stuff more than paying for complete solutions
I was thinking of a gear belt drive at first.. but it's a little impractical when you want 1:100 ratio or so..
Rotary Table Backlash fc911c General Metal Working Machines 4 04-18-2010 04:11 AM
Anti-backlash rotary joint existance TomB Linear and Rotary Motion 8 07-23-2009 12:01 PM
rotary table bulletfab Haas Mills 4 12-16-2007 02:48 PM
Rotary table Piobaire HURCO 0 08-22-2007 07:30 AM
Typical Backlash on a new Yuasa 8" Rotary Table Roy Norris General Metalwork Discussion 5 08-10-2005 04:33 AM
