Old 11-28-2004, 07:04 AM
Splint Splint is offline
Splint is on a distinguished road
A guide to permanent mold casting.
These are some pictures I took when I toured a pewter factory in Malaysia.
The permanent mold casting process uses molds, often made from metal, which are used over and over, as opposed to other techniques like sand casting, lost foam or investment casting where the molds are destroyed to remove the casting. The molds in this picture are for a handle on a mug, there are pins in the mating faces of the molds to align the halves correctly and steps cut in the top corners of the molds so the halves can be levered appart when it's time to remove the casting. When the molten pewter is poured from the ladel into the molds, the molds are clamped together and tilted up on an angle to reduce the likelyhood of an air lock in the casting, as the molds start to fill the angle is steadily reduced to horizontal. Pewter has a very low melting point and solidifies extreamly quickly.
Old 11-28-2004, 07:30 AM
As soon as the mold fills and pewter flows up through the riser, the lady turns the molds upside down to tip out the excess pewter left in the sprue and riser, puts the ladel back in the crucible then seperates the two mold halves. The time from the start of pouring to seperating the mold halves is about ten seconds, pretty quick. She then uses pliers to remove the casting from the mold.
Old 11-28-2004, 07:37 AM
Once the casting is free of the mold, the sprue and riser is submerged in the molten pewter in the crucible so they are melted off and reused, the casting is wiped (where the sprue and riser was) across the edge of the crucible to smooth of the surface in preperation for further processing.
Name:	sprue riser.jpg‎
Old 11-28-2004, 07:45 AM
This picture shows a few handles, the one at the bottom still has the sprue and riser on it. The handles are debured along the parting line, as there is usually a small abount of pewter which makes its' way outside the mold line which needs to be cleaned up. They are then fused to the body of the mug, polished and put in the show room for sale.
Old 11-28-2004, 09:30 AM
trubleshtr trubleshtr is offline
trubleshtr is on a distinguished road
Neat little process, what temp is the pewter at? she does not seem to be wearing much in the way of safety gear?
Old 11-28-2004, 10:08 AM
Lion's Den Lion's Den is offline
Lion's Den is on a distinguished road
Great Pics! Thanks for shareing
D
Think it, Plan it, Build it..... and hopefully it it'll work.
If it dosen't.... it was a prototype!
Old 11-28-2004, 12:50 PM
sendkeys sendkeys is offline
nice pics. I was thinking of doing some pm casting like she is doing there. But now that i see the parting line size. sure would make ALOT of work to clean it up.
as for another question pewter pours around 600-650f. If it was me i still have a little more protection haha.Pewter is cool but it's soft and cost is high.
Old 11-28-2004, 06:36 PM
Thanks guys,
I dont think there's really that much work in processing the castings, the picture of the handles shows the bottom one with the sprue and riser still attatched but they are simply melted off by submerging them in the molten pewter. After that you would need to use a scraper,file or deburing tool to give the parting line a clean up around the entire parting line (where the two halves of the mold join). Next you would file the surface (which would be done in a jig) where the handle mates to the body of the mug, after fusing the two together you wuld then polish and buff the part which wouldn't be overly difficult or time consuming if you had a buffing wheel on a bench grinder.
Cheers
Splint
p.s. Sorry, I dont know the exact melting point of pewter, perhaps around 200 to 250Deg. Celcius. There was a perspex sheild between the crucible and the audience, but I suspect pewter is faily stable and safe if you use a little comon sense. Having said that, I'll be covering up as much as possible and taking many precautions when I eventually start casting aluminium.
Cheers guys....
Casting Engine Parts Cnc Wana bee Jet Engines and Ram Jets 18 04-26-2009 01:39 AM
Beginner moldmaking questions fastturbovet Moldmaking 17 06-23-2005 04:38 PM
2 AL parts in need of casting mike_r Casting Metals 2 05-19-2005 05:09 PM
How to copy existing part to make a mold? dbassett74 Moldmaking 30 11-08-2004 08:20 PM
RFQ - Copper investment casting NeoMoses Employment Opportunity and RFQ (Request for Quote). 7 11-08-2004 06:39 PM
