Old 11-11-2004, 08:15 PM
CNCadmin's Avatar
CNCadmin CNCadmin is offline
Site Owner
Micro Mark Mini mill converstion
Well I'm finally done with my Micro Mark mini mill cnc conversion. I converted it it all ball screw and servo motor. I'm using Gecko 320 drives and camtronics power supply at 80 volt and 20amps. The system is geared 20:1 the ways were lapped and I replaced the gibs with brass.
The z axles was machine from Ron steels plans, and modified for servos.
ID:	3937   Click image for larger version
ID:	3938   Click image for larger version
ID:	3939   Click image for larger version
ID:	3941   Click image for larger version
Site Owner-Webmaster-
Administrator
www.rfqwork.com
Old 11-11-2004, 08:22 PM
CNCadmin's Avatar
Site Owner
Here are some pics of my z axis assembly.
ID:	3943   Click image for larger version
ID:	3944   Click image for larger version
Administrator
www.rfqwork.com
Old 11-11-2004, 08:30 PM
CNCadmin's Avatar
Site Owner
The belt pulley for the z axis is too big in dia and the motor for the spindle hit's it so I'm in the process of changing it.
Administrator
www.rfqwork.com
Old 11-11-2004, 09:47 PM
JFettig JFettig is offline
I assume you wont be running any coolant? Also, it looks like the X axis motor will be mighty close to the column? will it fit?
Have you considered converting your spindle to belt drive? Its much quieter and you can calculate the speed of your liking to an extent. 3000rpm is great for that motor, I have taken .25" deep cuts with a 3/8" rougher on mine at about 2500rpm and the machine started chattering before the motor crapped out.
Jon
Old 11-11-2004, 09:51 PM
CNCadmin's Avatar
Site Owner
No problem with clearance everything fit perfect just the one belt pulley I have to change.
I have looked every where for info on converting to belt drive, please share how to do it.
Administrator
www.rfqwork.com
Old 11-11-2004, 09:54 PM
balsaman's Avatar
balsaman balsaman is offline
Why the brass gibs?
I wish it wouldn't crash.
Old 11-11-2004, 10:00 PM
CNCadmin's Avatar
Site Owner
Lower coefficient than the iron on iron. When I lapped the stock set-up what i found was I was just wearing away the metal and had to keep tighten the set-screws, with the brass that did not happen and because of that I ended up with no play in the x and y.
Administrator
www.rfqwork.com
Old 11-11-2004, 10:24 PM
I took my spindle and all that other stuff apart so long ago that I dont even remember how it all went together and all, but basicly when you take off the motor mounting plate, theres a spacer ontop of the top bearing and on top of that is the spanner nut, I think thats how it goes, What I did is cut the spacer down, made a pully that goes over it and use the spanner nut and tighten it down on top of it, I made a pully that I press fit onto the motor shaft and a motor mounting plate. I am making a new motor mount for my new motor along with new pullies.
-edit- I too have brass gibs on my machine
Jon
Old 11-29-2004, 11:44 AM
HomeCNC's Avatar
HomeCNC HomeCNC is offline
HomeCNC is on a distinguished road
Paul,
On your first post in this thread you said you have the camtronics box running the servos at 80VDC!!! Thoes Clifton servos are rated at 12-60 with a nominal at 36VDC. Are they getting very hot when you run at that voltage?
Jeff Davis (HomeCNC)
http://www.homecnc.info
Old 11-29-2004, 12:56 PM
CNCadmin's Avatar
Site Owner
Yes I'm running 80vdc and no their not getting hot at all so far.
Administrator
www.rfqwork.com
Old 11-29-2004, 07:03 PM
balsaman's Avatar
They will only see the 80 volts when near stalled. Otherwise they see much less voltage.
Old 11-29-2004, 09:38 PM
balsaman's Avatar
Did you use the Mcmastercarr ballscrews? One nut or two per screw? Any backlash?
What size steppers for Grizzly mini mill? Mini Miller Benchtop Machines 14 07-18-2005 12:45 AM
Capabilities of mini mill @ $2500 jl123 Benchtop Machines 17 05-14-2005 10:59 AM
custom mini mill jimbo General Metal Working Machines 7 12-30-2004 11:33 AM
New to Mill and CNC - Can you mix a Mini and Micro Mill Sherpa Benchtop Machines 2 09-09-2004 10:36 AM
